best time to read gas gauge
Old 07-22-2008, 07:11 PM
bbsr72's Avatar
Car: 91 formula
Engine: 350 tpi
Transmission: auto
Axle/Gears: poss
whenm i first get in the car it says one thing ,then when the key is in "on" position it moves up. so which one is most likely true? it's never been on "E "before and isn't now either .are these car supposed to go to "E" when you turn the car off?
Old 07-22-2008, 08:33 PM
firebird896's Avatar
Car: '89 GTA/'86 TA/98 TA
Engine: 350/350/LS1
Transmission: R4/T5/4L60E
Axle/Gears: 3.23/2.77/3.73
Re: best time to read gas gauge
mine doesnt
Old 07-22-2008, 08:41 PM
cameron7710's Avatar
Car: 1992 Camaro RS
mine dosent go to e. i would trust when the cars on more than when its off
Old 07-23-2008, 08:52 AM
alicat's Avatar
Car: 1985 z28 camaro
Engine: 305 lg4,edelbrock,3"air cleaner.k&n
Transmission: turbo 700r4 w/b&m megashifter
Axle/Gears: Stock.
Most fuel gauges will go to empty when the key is off,unless they have a hold function,which these cars dont have.the needle will move when power is applied.
Old 07-23-2008, 10:22 AM
bbsr72's Avatar
Car: 91 formula
Engine: 350 tpi
Transmission: auto
Axle/Gears: poss
i hear tell cars with floating gauges don't go to E because there is stuff built up on the sending unit ,because most people don't run around on E? therefore, not letting the float go all the way down even though there isn't that much gas in the tank.
Old 07-23-2008, 12:12 PM
ghettocruiser's Avatar
Car: 86 Trans AM
Engine: LS1 (not stock...)
Transmission: Built T56
Axle/Gears: Strange 12-bolt w/ 3.73
Ok...to answer the question at hand. Reading the gauge with the ignition off tells you NOTHING... There has to be current running through the sender wire to the level sender in the tank in order for the gauge to read. If you shut the car off with a full tank, and the gauge still says full, and let the car sit for 10 years, and turn the car on, it will start off at full, but will quickly drop to where it needs to be due to evaporation. Thats the way sending units work. Its a measure of the resistance to ground. If there isnt voltage (usually less than 12 volts) going through the sender wire, the gauge wont read tank level. If you were to cut the sender wire, then turn your ignition on...the gauge would peg due to reading infinite resistance to ground. Not sure off hand which direction it would peg tho...
Now...as to why the fuel gauge doesnt go to zero when the car's shut off. I have a thought about that. Gauges in newer cars have buffers built in to them so that the sloshing fuel doesnt make them jump up and down. If they didnt have this, they would be all over the place (i.e. my 67 bonneville. no idea how much fuel was in that thing at any given time haha). I THINK...THINK...fuel gauges have an "air core" to dampen the movement. When you turn the gauge off, it doesnt "free drop" like the other gauges. The needle doesnt just go back and forth freely like the others. If you take a cluster, you can move the otehr gauges around all you want and they sort of spring back. But the fuel gauge is kind of stiff.
Im pretty sure thats how my autometer gauge works... Some cars might have the buffer thing in the tank, but Im 98% sure thirdgens dont.
Someone can correct me if Im wrong on the not going to zero thing...but I think thats what it is.
J.
Ghettobird52
12-29-2023 08:23 AM
Azrael91966669
DIY PROM
25
06-20-2017 04:04 AM
wayshegoes
08-17-2015 12:00 PM
Armored91Camaro
DIY PROM
08-12-2015 09:41 AM
Quick Reply: best time to read gas gauge
