setting up/adjusting kickdown for 700R4 and holley carb.
Old 06-30-2008, 09:13 AM
impaled's Avatar
Car: 1985 Camaro and 1996 Mustang GT
Engine: 350 4bbl/281
Transmission: 700R4/4R70W
Axle/Gears: 9" rear/8.8" 4.10
i am missing a part of the kickdown for my trans, and wanted to fabricate a bracket for it, but i didnt know about the tension so i called holley.
their tech rep. said that the 700R4's are really fussy with the kickdown and can burn up really easy if they are not adjusted right.
does anybody know how to properly adjust the kickdown cable?
Old 06-30-2008, 09:47 AM
The_Wraith's Avatar
Car: 1984 Trans Am 15th anniversary
Engine: L69
Transmission: 700r
Axle/Gears: 3:73
Re: setting up/adjusting kickdown for 700R4 and holley carb.
http://www.streetrodparts.tv/700R4_hookup.htm This link shows you how to adjust and make sure everything is right.
Another: http://www.tciauto.com/Products/Inst...ble_adjust.htm
I personally bought two parts from a local guy who got them from TCI. www.tciauto.com They sell the adapter for holleys.
Old 06-30-2008, 01:58 PM
five7kid's Avatar
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
Did the Holley tech rep mention the throttle arm corrector bracket?
Old 06-30-2008, 08:42 PM
impaled's Avatar
he gave these my part numbers but one said it didnt work with some earlier holley carbs.
http://holley.com/20-121.asp
http://holley.com/20-95.asp
Old 06-30-2008, 10:54 PM
five7kid's Avatar
Engine: LS1/LQ4
What Holley do you have? I doubt it's too old for that corrector bracket to work.
Old 07-01-2008, 12:51 AM
Tobias05's Avatar
Car: 1987 Camaro SC, 1999 Z28
Engine: GMPP 350HO, LS1
i have both those pieces on my 650DP. they work alright. i get my double downshift 4-2 when its on the floor, but my shift points are a little off.
I have a TV made EZ kit chilling in my car waiting to go on, if that says anything.
Old 07-01-2008, 08:58 AM
impaled's Avatar
3310-1 780 CFM (i think it was manufactured between 1960's and early 1970's)
Old 07-01-2008, 12:46 PM
five7kid's Avatar
Engine: LS1/LQ4
If you can, post a picture of the throttle arm from the side. That was a "universal" carb, most likely the corrector bracket will fit. If not, get a new primary throttle shaft from Holley (or Proform, or Quick Fuel, or. . . ).
Old 07-01-2008, 05:20 PM
The_Wraith's Avatar
Engine: L69
Transmission: 700r
Axle/Gears: 3:73
Does anyone have the measurement from the factory q-jet TV cable to the bracket? Also can anyone verify that the TV cable should be fully extended at WOT? I got both brackets from TCI but im not sure if its bolt in and go.
Frozer!!!
01-19-2024 04:55 PM
Reddeath210
10-06-2015 08:20 AM
Zeek1041
Theoretical and Street Racing
08-21-2015 08:45 PM
Dialed_In
08-20-2015 01:45 PM
TreDeClaw
08-14-2015 06:58 PM
Quick Reply: setting up/adjusting kickdown for 700R4 and holley carb.
