tv cable help new carb and stuff
Old 06-26-2008, 09:57 PM
iroc3o5's Avatar
i need some help.
i just put an edelbrock 1405 performer carb and performer intake on my 86 305 camaro. but there is no tv cable hookup on the throttle linkage of the new carb.
tci sells an Edelbrock® carburetor TV Cable geometry corrector kit part number 376710
and a 700R4 & 2004R Carter® AFB™, Quadrajet™, Edelbrock® TV Cable Bracket part number 376700
if i buy these parts i should be able to hook up my tv cable correctly right??
do i really need the second part, the bracket, or can i use my stock one??
any help would be appreciated thank you
and here is a link to the tci site
http://www.tciauto.com/Products/gm/gm_4L60E.asp
Old 06-26-2008, 10:03 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Axle/Gears: 3.54 Dana 44
Re: tv cable help new carb and stuff
The stock bracket will mount the TV cable too far forward. I believe I've tried that particular bracket you mention. It works best with a thick carb gasket, but you might have trouble using the vacuum break port on the back of the carb, or on manifolds.
iroc3o5's Avatar
other companies sell the same product it seems to correct this problem,
transmission center
http://www.transmissioncenter.net/highperf700r4.htm
# 29 on list is the geometry corrector that bolts to throttle linkage
fourthgearinc
http://fourthgearinc.com/700_R4_Street_Rod.htm
phoenix trans
http://phoenixtrans.com/html/tvcablekits.html
so i need the edelbrock carburetor TV Cable geometry corrector kit part number 376710
and the bracket and a 700R4 & 2004R Carter® AFB™, Quadrajet™, Edelbrock® TV Cable Bracket part number 376700
i just wanna drive my **** man i just put all this new crap on!!!
just did msd 6 al ignition, msd pro billet dizzy, msd wires, msd blaster, the intake, the carb, k&n filter, headers, y pipe, cat back.... i wanna drive it man!!1
Last edited by iroc3o5; 06-26-2008 at 10:07 PM. Reason: i kick *** but no nothing about tv cables
Old 06-26-2008, 10:06 PM
Apeiron's Avatar
Engine: 383 Carb
Old 06-26-2008, 10:10 PM
iroc3o5's Avatar
oight son thanks
Old 06-26-2008, 10:12 PM
Tobias05's Avatar
Car: 1987 Camaro SC, 1999 Z28
Engine: GMPP 350HO, LS1
http://www.bowtieoverdrives.com/cata...php?ITEMID=213
don't forget the 10$ throttle bracket that bolts on.
Old 06-26-2008, 10:17 PM
iroc3o5's Avatar
i just bought this from tci
Code
Product
Quantity
Price/Ea.
Total
376700
700-R4/200-4R TV Cable Bracket - Quadrajet™
$27.18
$27.18
376710
TV Cable Corrector Kit for Edelbrock
$37.15
$37.15
Shipping: FedEx 2day:
$10.51
Sales Tax:
$0.00
Total:
$74.84
you just mentioned another bracket for 10$, but that link you linked me to a 120$ kit
http://www.bowtieoverdrives.com/cata...BCAT&CATID=WA4
is a list of the 10$ adapters i think you are talking about. how do i know which to buy? my car has no cruise or anything...
it says those brackets work with their EZ kits only
Old 06-27-2008, 12:57 AM
Tobias05's Avatar
ya i was refering to the kit and the bracket, before you bought your stuff.
interested to see that bracket from tci.
EZ kits are considered some of the best you can buy. even if you don't buy their products, spend a few hours reading their articles on how the TV system works, you'll learn a ton...i did.
Old 06-27-2008, 07:16 AM
iroc3o5's Avatar
oight son, i'll look into that
Old 06-05-2009, 02:48 AM
g/f's z's Avatar
guess, ill dig up an old thread.....will this fit on my edelbrock 1406?
http://store.summitracing.com/partde...700+4294865279
Old 06-05-2009, 07:46 AM
iroc3o5's Avatar
that fits on the intake manifold, and yes you need it. you also need the bracket that attatches to the carb arm. i think the technical term edelbrock calls the bracket is a "geometry corrector" so that the tv cable hooks onto the carb, and the geometry is more similar to stock
GeneralIesrussi
Carburetors
01-20-2020 01:06 PM
TheTraut88
09-11-2015 05:16 AM
TheTraut88
09-07-2015 05:22 PM
Buickstaged
Brakes
09-04-2015 07:53 AM
GeneralIesrussi
09-03-2015 03:23 AM
Quick Reply: tv cable help new carb and stuff
