should i paint racing stripes before/after basecoat?
Old 06-19-2008, 03:16 PM
tripingeorge3's Avatar
bought paint for cars super jet black i stage paint. i'm going to put on silver racing stripes. i'm worried about paint being dry to mask and paint the stripes and also about the paint lines. i am applying xtreme clearcoat over the paint last even though its a one stage paint i am using. should i spray the silver on the hood and spoiler first , then mask of in the design of the stripes, then apply black paint, or doi it normal with stirpes after base. if i do it that way shound i tape the stripe designs then sand and paint or would i just be ble to tape the spray silver. help please. friday is d day
Old 06-19-2008, 04:20 PM
greatpumpkin_68's Avatar
Car: 1987 IROC & 1968 Nova
Engine: 5.0 TPI & 350
Transmission: 700R4 & powerglide
Re: should i paint racing stripes before/after basecoat?
i am no expert but i am pretty sure that you spray the whole car with your base coat.. let it dry.. mask the stipes and then spray them with no sanding..let it dry and lay down the clear.
like i said.. i'm no chip foose, but i'm pretty sure that's how he would do it.
Old 06-19-2008, 05:09 PM
Titan85's Avatar
Car: 1987 Camaro SC
Engine: 305 LB9
Axle/Gears: 3:42
I am also looking into this. From what I have seen, the stock stripes are actually stick on (strange, but we are talking GM here ). I believe stripes are normally painted over the base coat and then clear goes over that.
Why are you using a one stage paint and then putting clear over it? I am assuming you mean the old style enamel paint. I am most certainly no expert, but I think there is a reason why base/clear is done with different paint than one stage painting.
Old 06-19-2008, 05:29 PM
its urethane enamel, and on the directions its says for a show car shine , clearcoat can be added over it.
Old 06-19-2008, 05:54 PM
89importeater's Avatar
Car: 89 RS camaro
Engine: 454 swap in progress
Transmission: th400
Axle/Gears: 4.11
yes its fine to clear over singlestage paint and what i would do is base the whole car, let it dry tape out your stipe then sand lighty with like 600 grit then spray. if you dont sand the single stage paint before you apply the stripe it could cause problems. paint needs some sort of texture to stick to. you may not be able to feel the texture if sanded with 600 or up but it is their. if you where using a base/clear for the car then you wouldnt need to sand it before spraying the stripe but since you are using singlestage it would be like trying to paint a car that still has a shine on it, it wouldnt stick.
Old 06-19-2008, 06:23 PM
Old 06-19-2008, 06:28 PM
Car: 89 RS camaro
Transmission: th400
Axle/Gears: 4.11
ok.............i didnt say you couldnt clear over it, we clear over singlestage at work all the time. why did you say that?
Old 06-19-2008, 06:30 PM
if i let the single stage black dry, will the clear still stick properly, i don't want to sand the black to apply the clearcoat.
Old 06-19-2008, 06:36 PM
Tmic87TPI's Avatar
Car: 1987 Trans Am
Transmission: t56
tape the stripes after the black dries, then scuff your black (I'd use 400-600), before you put down the silver, then untape it and clear it all.
Old 06-19-2008, 07:10 PM
thats my question, my single stage paint doesn't have to have clear but i'm doing it anyway. the single by itself has an amazing shine so i figured on top of that shine apply the clearcoat and i thought it should then be like its wet all the time, but if i scuff wouldn't that kill the shine of the single stage
Old 06-19-2008, 07:21 PM
Car: 89 RS camaro
Transmission: th400
Axle/Gears: 4.11
you dont scuff the whole car just tape out the stripe and scuff the unmasked area where you are about to apply paint. then clear the whole car. and yes the clear should stick. you could also do a test panel to make sure like an old door or something you have lying around.
Old 06-19-2008, 07:24 PM
oh ok . sorry i'm at work. my mind is on many things at once. i getit. now the only thing left is to do it.
oh by the way , do to budgeting issues i'm using spray can silver for the stripes. i'm thinking it should still work out.
Last edited by tripingeorge3; 06-19-2008 at 07:27 PM. Reason: Automerged Doublepost
Old 06-19-2008, 08:18 PM
rosco88ta's Avatar
Car: 88 Trans Am
Engine: 355 c.i.
Transmission: 5 spd.
Axle/Gears: 3:42s
That's not the proper way to do a paint job but, WHATEVER!!!!
Old 06-19-2008, 08:45 PM
Tmic87TPI's Avatar
Car: 1987 Trans Am
Transmission: t56
I see nothing wrong with it except the spray can part, what do you mean its not the proper way?
Old 06-19-2008, 08:49 PM
rosco88ta's Avatar
Car: 88 Trans Am
Engine: 355 c.i.
Axle/Gears: 3:42s
TMIC Would you scuff a metalic base coat? I know you can sand solid color but never metalics. Rattle can over single stage then clear over rattle can paint, just asking for trouble.... Just must humble opinion
Old 06-19-2008, 08:56 PM
Tmic87TPI's Avatar
Car: 1987 Trans Am
Transmission: t56
why wouldn't you scuff metallic basecoat? hes just scuffing it so the silver will have a surface to stick to, but I'm not really familiar with metallics, is there a reason you can't scuff them? and I can't agree more, spraying clear over rattle canned paint just sounds like trouble.
Old 06-19-2008, 09:28 PM
Charged350's Avatar
Car: 87 IROC Z28
Engine: Custom Forged 355
Axle/Gears: 9" 4:11's Detroit Locker
do yourself a favor, if your going to clear it, the use black urathane meant to be cleared as a two stage paint job, not clear over your single stage. i recomend this highly, but what do i know, im just a professional painter. if your gonna do it, do it right.
Old 06-19-2008, 09:34 PM
Car: 89 RS camaro
Transmission: th400
Axle/Gears: 4.11
i semi agree with charged 350, if i know without a doubt that i was gonna clear then i would use a base clear system, but on the other note i am also a painter at one of the largest independent shops in NC and we clear over single stage ALOT. yes sometimes we run in to trouble mostly with "sweatback" but its nothing that a little water sanding and buffing wont fix. i figured since you already had the paint you could give it a shot but whatever you wanna do, afterall it is your car.
Old 06-19-2008, 11:43 PM
the paint supplier recommends clear over the single stage for superior gloss.
Quantity in Basket:none
Code: kitu_jetblack
Price:$72.00
Quantity: • High solids, high build finish • Extremely fast drying
• Sprayable using conventional or HVLP equipment
• Abrasion and impact resistant
• Outstanding durability
• Sharp automotive gloss appearance
• High distinctness of image (DOI)
• Excellent color retention and fade resistance
• Outstanding resistance to gasoline and diesel fuel
• Excellent flexibility and adhesion over primed surface
• 25 premium colors available with new colors being added all the time
• Superior flow out and leveling
• High UV formula contents protects against fading
• Offers superior durability over other single stage finishes
• Can be applied as a single stage acrylic urethane or top coated with our Urethane clear for base coat clear two stage results
Hawthorne "Starfire" Urethane acrylic is a is a premium quality, single-stage OEM/Refinishing System which provides excellent gloss and durability in an easy to apply economical single-stage package. Its advanced urethane formula provides unsurpassed durability and gloss. Hawthorne Starfire Urethane Acrylic is a state-of-the-art, 2.8 VOC formulation providing excellent resistance to solvents, chemicals, gasoline, fading, chipping, abrasions and scratches. Starfire provides a high degree of UV protection to help keep vehicles looking glossy and deep in color for years.
Old 06-20-2008, 01:27 AM
green92's Avatar
Car: 92 RS
Axle/Gears: 3.08
You may run into a problem clearing over the rattle can paint. It may cause the clear to crack fisheye etc. I would suggest picking up some silver paint to stripe with the clear, just due to the fact clear coat is awesome but very tempermental.
Old 06-20-2008, 10:32 PM
i don't know if you are interested, but i am sure that o'reillys carries pre-mixed quarts of base coat (only in a few colors though.. i am pretty sure they have silver). it is usually next to the spray cans.. i believe it is a duplicolor system. they carry the clear also. i believe it is pretty inexpensive too... just thought i would throw that out there as an option to the rattle can.
Old 09-27-2009, 03:44 PM
Frassit's Avatar
Re: How to repaint a cleaar coat base coat?
I just painted my car with a clear coat base coat and wanted to give it another coat after the clear dried. I lightly sanded the clear and re cleared it and the paint wrinkeled like painting lacquer over enamal. What do I need to do to repaint?
Old 09-27-2009, 08:50 PM
bsporty's Avatar
Car: 85 Z28
Transmission: 5 speed
I would base and clear the whole car.Sand the panels that are getting the stripe with 600.Lay out the stirpe, tape it out,and base the stripe.Remove the paper and tape from the stripe and re clear the panels where the stripe is.
Old 09-28-2009, 10:44 AM
SLOWMARO355's Avatar
Base coar/clear coat is the way to go. https://www.thirdgen.org/forums/body...nts-first.html
Hotrodboba400
12-10-2019 07:07 PM
Drone358
12-10-2015 08:16 PM
TheExaminer
09-06-2015 11:40 PM
Amillionoh7
09-05-2015 11:44 PM
Hotrodboba400
09-02-2015 07:28 PM
Quick Reply: should i paint racing stripes before/after basecoat?
