idle fluctuation problem - Comp Cam too big?
Car: 91 Bird
Engine: TPI 350
Transmission: 5-Speed
Axle/Gears: 2.77 posi
fluctuates at idle but NOT with a/c on. With A/C on it is just fine. A/C off it fluctuates. SES is showing no codes.
adjusted IAC to 450 then plugged it back in. it idled different with IAC. SO it is doing something - but maybe not the right thing.
adjusted TPS to .54 at idle and it is at 4.38 WOT. Seems to be smooth going up from idle to wot.
IAC is about two years old. Seemed to work well during that time.
TPS is about 1.5 years old but sitting up the whole time on an engine - never used.
Timing is about at 10 deg advanced without ecm
5-speed manual
new engine swapped in - 350 TPI (now has 30 miles on engine). was 305 TBI. changed wire harness and ecm. I double checked the ecm it was for a 1989 350 TPI with a MAF.
cam - Comp Cams CS XR258HR-10
Int 258 exh 264
duration @ .05 206 212
valve lift .480 .487
lobe sep 110
flat top pistons - 4 valve relief. 0.020 over
other than the idle it runs fine. very smooth acceleration.
Thanks for the help.
5-speed manual
Int 258 exh 264
lobe sep 110
Car: 91 Bird
Engine: TPI 350
Re: idle fluctuation problem - Comp Cam too big?
Any guesses? MAF? IAC? TPS? WHat would you bet on?
This is my first roller cam engine, first TPI, first with MAF, so I would like opinions.
I know the cam is not really that big but I don't know at what point the idle will be affected
Thanks!
Thanks!
1988iroc350tpi
08-14-2015 07:52 PM
