Washer for Ball Joint rubber boot
Old 05-31-2008, 01:01 PM
Firebat's Avatar
Replacing the ball joints. Noticed the new ball joint kit I have doesn't have these washers that were on top of the rubber boot. These washers look like pure hell, they are really beat up or worn out.
Do I need these washers? Can I get them separately or do I need to get some different ball joint kits?
Also, are polyurethane ball joint boots worth getting?
Old 05-31-2008, 05:16 PM
Firebat's Avatar
Re: Washer for Ball Joint rubber boot
I don't think its a washer, i'm thinkin its part of the old shot ball joint
Old 05-31-2008, 07:07 PM
BADMAN's Avatar
Car: 1985 Iroc-Z
Engine: 440LSX
Transmission: l460e
Axle/Gears: 3.55 Wavetrac
Use Moog Problem Solver ball joint. Has a better boot that channels grease away form brakes when installed correctly. Also stronger than stock.
Old 05-31-2008, 08:01 PM
Firebat's Avatar
who sells the moog problem solver ball joint? About how much does it run? I picked up some $10 ball joints from o'reillys but am considering taking them back, the ones I have come with a lifetime guaranntee but I really don't want to replace these again soon.
Old 05-31-2008, 08:59 PM
BADMAN's Avatar
Car: 1985 Iroc-Z
Engine: 440LSX
Transmission: l460e
O'Reillys, Autozone, any good auto parts store or maybe Rockauto.com on the net. Cost about $22.00-25.00 each. Much better than those cheap $10.00 ones and will last much longer. Take the one's you bought and compare them to Moog. See the difference.
Old 05-31-2008, 09:03 PM
BADMAN's Avatar
Car: 1985 Iroc-Z
Engine: 440LSX
Transmission: l460e
Pic of front end rebuild using all Moog parts.
Attached Thumbnails Washer for Ball Joint rubber boot-torque-arm-camaro-006.jpg
Ed1LE
09-30-2018 09:14 AM
Fireslash
04-11-2016 06:43 PM
loud91rs
10-05-2015 10:05 PM
sjorgens
10-01-2015 07:54 PM
Gordonr1973
09-29-2015 11:59 AM
Quick Reply: Washer for Ball Joint rubber boot
