exhaust system ideas for an 84 camaro
Old 05-27-2008, 06:19 PM
theorio1025's Avatar
Car: 1984 Camaro Z28
Engine: 350 from an elcamino
Transmission: stock t-5
Axle/Gears: 10 bolt 3.73 limited slip
i have a basically stock 350 with a t5 in the car. 3.23 limited slip rear. Im looking to put headers with a full exhaust on it. i was thinking about these headers and y pipe
http://store.summitracing.com/partde...5&autoview=sku
i was wondering what cat, and cat back would be a good idea to use with this. im not looking for anything that has to be modified, as i dont have the tools or experience.
Old 05-28-2008, 01:25 AM
five7kid's Avatar
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
For another $50, you can have much better headers and y-pipe
http://store.summitracing.com/partde...0&autoview=sku
Cat, CTO-9118.
Cat-back, whatever you want that's made for the '86-'90 TPI single-cat application.
That stuff will all bolt in (with the possible exception of a hanger or two).
Old 05-28-2008, 06:32 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: exhaust system ideas for an 84 camaro
Originally Posted by theorio1025
im not looking for anything that has to be modified....
The following is a direct-fit system (no modding whatsoever):
Hooker 2055's (Jeg's 520-2055). Catco high-flow converter (Summit CTO-9118). Hooker catback (Summit HOK-16823HKR).
JamesC
Old 05-28-2008, 09:50 AM
the 2055's have the air tubes for emissions, but im not running any of that on the car. the previous owner removed it, and i only have one more year till im emissions free. how would i remove those, or do they make a set without them?
Old 05-28-2008, 10:24 AM
JamesC's Avatar
Cut and weld, which is what I did. No biggie.
JamesC
Old 05-28-2008, 10:05 PM
is there anyway other than welding?
Old 05-29-2008, 06:36 AM
JamesC's Avatar
Don't know what it would be. Check the following link for pics that show the welds (the paint's wearing now, but originally the welds were difficult to see):
https://www.thirdgen.org/forums/afte...rsion-kit.html
JamesC
Old 05-29-2008, 09:37 AM
Timothayyy's Avatar
Car: 1992 Firebird
Engine: 350TBI
Axle/Gears: Ford 9in 4.10
If you just want headers without the air tubes, get the hooker 2460's with the matching y-pipe.
Old 05-29-2008, 12:41 PM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
the 2460's y-pipe is way overpriced. you could always get the 2055's, cut the air tubes off, then just tap the tubes and put some short pipe threaded plugs in it's place. OR...take them to your local muffler shop and have one of the guys there do it for a small price. the 2055's are just such a better header/y-pipe combo than the 2460's.
Old 05-29-2008, 02:16 PM
the idea of plugging the holes with pipe plugs sounds good. thanks for all the help
Old 05-30-2008, 12:37 AM
five7kid's Avatar
Engine: LS1/LQ4
Welding the tubes shut is extremely easy to do. Anyone with a wire welder can do it.
Check the pics in my vB Garage.
Vintageracer
01-10-2020 05:33 PM
Fast355
12-02-2016 06:33 PM
makaveli09
08-12-2015 09:07 PM
mustangman65_79
08-07-2015 09:55 PM
Quick Reply: exhaust system ideas for an 84 camaro
