how much paint do i need to paint my car
Old 05-23-2008, 04:02 PM
tripingeorge3's Avatar
its t top , i'm doing the door jams and back hatch area also . so there is now more red paint showing . i have a gallon of super jet black and 1 gallon of clear. aslo how many coats of clear should i use. was thinking og getting another gallon of clear .
Old 05-23-2008, 04:19 PM
zipfast's Avatar
Car: 94 9c1 Caprice
Engine: LT1 (3-fity)
Transmission: 4L60E reBUILT
Axle/Gears: 3:08 POSI (out)
Re: how much paint do i need to paint my car
I would guess you are talking base / clear?
If so, thats plenty. Are you planning to sand and buff the clear?
Old 05-23-2008, 04:20 PM
Tmic87TPI's Avatar
Car: 1987 Trans Am
Transmission: t56
one gallon of base will be enough, and one gallon of clear will be enough, Id go 3-4 coats of base (only cuz your doing a color change with no sealer) and 3-4 coats of clear.
Old 05-23-2008, 04:26 PM
400Z28Racer's Avatar
Car: 85 IROC-Z
Engine: 406
Axle/Gears: 9" 411
1 gallon is more than enough, I painted my Silverado extended cab 2 base 3 clear and i had little left over
Old 05-23-2008, 05:14 PM
hot92RS's Avatar
Car: 92 Z-28
Transmission: THM700R4
AUTOMOTIVE PAINT2QUARTS PPG DP90LF BLACK EPOXY LF
AUTOMOTIVE PAINT1 QUART PPG DP402LF EPOZY PRIMER CATALYST
AUTOMOTIVE PAINT3QUARTS PPG MBCC 4265
AUTOMOTIVE PAINT1GALLON PPG MC161 AU H.S. URETHANE CLEAR
AUTOMOTIVE PAINT2QUARTS PPG ALL FAST TOPCOAT HARDENER
AUTOMOTIVE PAINT1GALLON PPG MR 187 AR SLOW REDUCER
This is what I bought to paint my entire car. It was a slight color change from the stock teal color. There was virtually no body work that needed to be done.
Old 05-23-2008, 05:44 PM
yes i'm planning to sand a buff clear. but that brings another question. how long do i have to wait for the clear to dry to sand/buff ?
Old 05-23-2008, 11:27 PM
irocman79's Avatar
Car: 1989 Iroc Camaro
Engine: Stock 350 TPI
how flat do you want your paint job. is this going to be a show car or daily driver. If is going to be a show car i would spray on 2 good coats of clear than knock the the orange peal with some 320 or 400 grit sand paper. the go over that with 2 or 3 cross coats than buff should be super smooth. if just a daily driver go with 3 cross coats. as for how long before you can buff. will you be able to bake it. if can bake it you should be able to buff it in a day or so or when ever the paint is fully cooled. if you don't bake it. probably 2 or 3 days i would guess. just so it is not tacky at all. It takes a long time for paint to full cure. you don't want to wait to long as the clear gets fully cured it gets harder and as it gets harder it will get harder to buff. If you have not ever buffed before make sure you follow the directions with the pad and the compound. You will not want to get your fresh paint to hot. run your buffer slow with light pressure.
Exxon Limited
Camaros Wanted
22
12-21-2015 10:36 PM
kah992
08-19-2015 02:55 PM
ElPaleterro85
08-13-2015 03:49 PM
Exxon Limited
08-09-2015 08:13 PM
kyle5647
08-07-2015 03:08 PM
Quick Reply: how much paint do i need to paint my car
