Center bolt valve covers n roller rockers
Old 05-14-2008, 01:00 PM
Huffs_91_RS's Avatar
Car: 84 Z28
Engine: 383
Axle/Gears: 342 Posi
I bought some center bolt valve covers for my new engine which I had head work done, in which I put some aluminum roller rockers on them. The valve covers hit the rockers before there all the way down. There just stock height. Will tall center bolt valve covers clear the rockers? Ive seen where people have bought the thinner rockers. I dont have that option. So what have u guys done to use the roller rockers n get the center bolt valve covers to clear? So any help r advice would b great. Thanks HUFF
Old 05-14-2008, 01:13 PM
heat seeker's Avatar
Car: 89 Formula
Engine: 383 SBC/HSR
Re: Center bolt valve covers n roller rockers
I believe they make spacers and adapters (either or) for installing Low-profile valve covers on cars with aluminum roller-rockers. The adapters allow you to keep your heads the same, but switch to side bolt valve covers which you would need the taller ones.
Check Jegs, or Summit catalog and you should find some there.
Old 05-14-2008, 05:49 PM
skinny z's Avatar
In my case, which is Comp Pro Magnum rockers and stock stamped steel valve covers, it was necessary to clearence the valve cover bolt hole support.
I used a die grinder to trim the support so it cleared the rocker body.
Old 07-13-2008, 09:00 AM
GTA Sammy's Avatar
Car: 1989 T-Top GTA
Engine: 5.7L TPI> 6.2L
Transmission: 700R-4
Skinny Z do you have any pics? I have to do the exact same thing....
Old 07-13-2008, 04:48 PM
skinny z's Avatar
Not at this time, however sometime this week (or so ) I'll have to reset the lifter preload on the fresh engine. I can probably get a couple of pics then.
Old 07-15-2008, 10:19 PM
skinny z's Avatar
You can see from a couple of these shots how much material needs to be removed from the support. It's only one side (the side that goes between the rocker bodies) however most of the 'lip' has to be removed.
Hope it's helpful.
Attached Thumbnails Center bolt valve covers n roller rockers-rocker-clearence-1.jpg   Center bolt valve covers n roller rockers-rocker-clearence-2.jpg   Center bolt valve covers n roller rockers-rocker-clearence-3.jpg
Old 07-16-2008, 12:05 AM
customblackbird's Avatar
Car: 87 TA clone
Engine: supercharged 5.3 LS
Transmission: bullet proof 2004R
Axle/Gears: ford 8.8, 3.55 gears
did u get the narrow body self aligning roller rockers? thats wat center bolt valve covers require.
or u could get fabricated aluminum tall center bolt valve covers and call it a day
Old 07-16-2008, 07:41 AM
skinny z's Avatar
I machined my Vortecs heads for guide plates and am using Comp Cams 1302 rocker arms. I wanted some interchangability should I upgrade my heads and can't use self aligning rockers. They are standard width.
Stock steel covers because I spent my money on go fast parts.
Old 07-16-2008, 02:11 PM
Car: 87 TA clone
understood, those are nice rockers. i only spent 80$ on fabricated aluminum center bolt valve covers with billet rails....
Old 07-16-2008, 04:53 PM
skinny z's Avatar
I like the fabricated look. Where did you get them?
Old 07-16-2008, 05:26 PM
GTA Sammy's Avatar
Car: 1989 T-Top GTA
Thanks SkinnyZ, that's exacltly what I was looking for!!!!
Let the grinding begin!!!!
Old 07-16-2008, 05:45 PM
Car: 87 TA clone
skips white performance... he has a store on ebay. the attached pic is of his perimeter valve covers for 73$ but idk if he still carries the center bolt covers. i might have gotten one of the last pairs months ago. mine are polished and look great and are really really light greats welds too
Attached Thumbnails Center bolt valve covers n roller rockers-270254669131_1_0_1.jpg
Old 07-17-2008, 01:14 AM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
Adapters are pricy. You got two options:
1. Take a dremel to the valve cover supports and clearance them.
2. Get tall valvecovers.
I've got guideplates and non self-alligning rockers on a set of Vortecs. I'm guessing you're in the same predicament. I liked tall valve covers so it was an easy choice.
Some people run into problems where the alternator bolt hits the valvecover (when they're tall) but mine have room there, so no problems at all for me. I just always get it zapped when I pull that side off the car with the battery connected. THat bolt arcs straight to the valve cover every time. So I disconnect the battery. And then I always forget to reconnect it... Good times.
Old 07-17-2008, 09:11 PM
skinny z's Avatar
InfernalVortex
Whats your hood clearence like? It looks like you use a low profile element.
My RPM Air Gap pushes the filter lid into the hood. The dropped base I use means I need a 3" element in order to clear the choke housing.
Old 07-17-2008, 09:14 PM
Car: 1992 Camaro RS
It's a drop base with a 1.5 inch filter. It was a Summit brand K&N ripoff. Probably a K&N filter anyway. But my hood clearance is fine. I dont know how much more clearance I have, but the way it is, it doesnt hit.
I think my intake is actually taller than the air gap by 1/8 of an inch or so. It's a GMPP Vortec dual plane intake.
I'm not sure I'll keep that filter setup, though. THe filter will be kpt but I may get a different base/lid. The lid comes way too close to the top of the carb so I worry about it limiting my airflow pretty bad.
Old 07-18-2008, 05:19 PM
skinny z's Avatar
That's what I noticed about using a dropped base with a short filter element. Not enough room above the choke horn (about 0").
It's either a cowl hood (but I don't like the added attention it brings) or I'll modify an OEM twin element filter housing (TPI sytle) to mate with a standard 14" open filter housing but replace the 14" filter with some sheet steel or aluminium cut to a height that'll allow some hood clearence.
Got to have some cold air coming in!
midge54
12-27-2019 04:14 PM
LT1Formula
08-20-2015 09:36 PM
IrocZ'85
08-17-2015 06:24 PM
blackd-out z28
08-15-2015 08:18 PM
mustangman65_79
08-08-2015 01:18 AM
Quick Reply: Center bolt valve covers n roller rockers
