trans vibration... getting worse
Old 05-07-2008, 10:31 AM
thunder85's Avatar
Car: 1988 firebird trans am GTA
Engine: 5.7L w/hsr
Axle/Gears: posi 3.23
hey all,
i have a 700r4 with about 105k miles on it. i am getting an odd thrumming vibration intermittently when driving the thing.. but its most severe when at a set speed (cruise control on the highway) at around 65-75mph or decelerating . its slightly noticeable when accelerating, but very slight. when i pop it into neutral at these speeds, its as smooth and quiet as can be. when decelerating (in gear) it is also quite noticeable all the way to about 30(ish). this isn't an **** retentive just barely noticeable vibration either... it rattles the change in my ashtray.
i know this is fairly general, but what do you think i should do first? i am going to have the fluid flushed and filter changed just to see if there are any pieces or debris in the pan to be concerned about, and i am considering changing the ujoints just as a precaution. if these things don't help, what is my next diagnostic step?
thanks all,
thunder
additional info: this might not be part of the same problem, but there is a 1-2 second lag before my car will shift into drive or reverse. i click the shifter... wait... then it engages.
Old 05-07-2008, 02:48 PM
thunder85's Avatar
Engine: 5.7L w/hsr
Re: trans vibration... getting worse
and yes, i know there are other posts about tranny vibration in a 700r4... but none of them that i have found had all vibration go away upon popping the car into neutral at highway speeds...
Old 05-08-2008, 07:47 AM
mpb74's Avatar
Car: 1986 Iroc-Z
Engine: 355 Phase 2 Bowtie heads
Axle/Gears: 342
maybe its your drive shaft.
Old 05-08-2008, 09:47 AM
thunder85's Avatar
Engine: 5.7L w/hsr
if that were the case, wouldn't the vibration stay when i was in neutral at highway speed? the drive shaft is still spinning at the same rpm
Old 05-08-2008, 07:33 PM
Tim91RS's Avatar
Car: 91 Camaro RS
Axle/Gears: stock
i got a used 700r4 and put it in recently because mine went out bad.
It vibrates when i accelerate slow but it is give it a decent about a gas it does not really do it.
Most of the time when it does it during accel i can pop into 3rd and it smooth again.
it does not burn fluid or slip
also if im slowing down and try to gun it again it vibrates
to me its feels like if i was shifting into 5th to early in a 5 speed
like maybe the tranny is going into OD to soon i dunno
i just dont feel like taking it back out lol
yurs doing anything like this?
Old 05-08-2008, 10:13 PM
82Five-O's Avatar
Car: 82 Sport coupe
Engine: 355 semi roller
Transmission: TH-350 B&M ratchet shifter
Axle/Gears: 3.73 Eaton Posi
check the mount
Old 05-08-2008, 10:23 PM
TADailyDriver's Avatar
Car: 1988 Trans Am, 2005 Sierra 2500
Engine: Vortec 357
Transmission: Built TH700R4 with 26-2800 Stall
Axle/Gears: GM 10 bolt 3.73 Posi
sounds liek u joints if it shakes on deacceleration. Could also be the mount.
Old 05-08-2008, 11:53 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
U JOINTS
Old 05-09-2008, 11:56 AM
thunder85's Avatar
Engine: 5.7L w/hsr
tim91, yes, i do get that... when its cruizing it vibrates, but when i punch it the vibration reduces by about 80%.
i will buy U joints and drop the driveshaft tonight. i need to change the tranny mount and install my ds loop anyhow, perfect excuse. is there a brand recommended?
on an additional side note... if i want to kill my tc lockup without burning a test chip what do i unplug? i am wondering if its a combination of issues with maybe the u joints, bad mount, and shuddering tc lockup clutch
Old 05-11-2008, 07:39 AM
thunder85's Avatar
Engine: 5.7L w/hsr
update:
u joints weren't bad, but were old so i replaced them. changed tranny fluid and had no chunks of metal or any debris... just the usual silver sludge stuck to the magnet. i'm putting all high mileage tranny fluid and 1qt of Lucas transmission treatement. the tranny mount was good and fairly new looking, but rubber. i am changing it out with a new urethane bushing (and installing my ds loop). i'm also putting posi treatment into my diff... see if maybe thats vibrating some too.
could a jacked up tc cause these issues?
Old 05-11-2008, 05:14 PM
Tim91RS's Avatar
Car: 91 Camaro RS
Axle/Gears: stock
thats what I wanna know to the TC on my 700 is from a caprice and my 700 is from a truck.....my original 700r4 had to much clutch dust in it after the tranny burned up to save the orig tc
92camaroJoe
07-29-2023 07:57 PM
25thannivZ28
Aftermarket Product Review
01-02-2016 05:41 PM
Bubbajones_ya
08-28-2015 02:17 AM
92camaroJoe
08-13-2015 06:07 AM
IROCThe5.7L
DIY PROM
08-10-2015 11:24 AM
Quick Reply: trans vibration... getting worse
