Coil keeps burning out
Old 04-21-2008, 08:10 PM
84olmpcboy's Avatar
Car: 84 olympic edition camaro
Engine: 2.8
I bought an 84 camaro 2.8 about six months ago, Since then I rebuilt the carb, put on a new ignition system, and put on a new starter. Before i did all the work the car ran fine but it needed the tune up. Now it wont start and keeps burning out coils. I rechecked all my wiring and it all seems to be fine. I cant think of anything else that could be wrong except a short. Any ideas???
Old 04-24-2008, 10:39 PM
jstrdn90rs's Avatar
Car: 90 RS/90 Z-71/73 Vega
Engine: 3.1/5.7 TBI/5.7
Transmission: 700R4/700R4/350turbo
Axle/Gears: 3.23/3.42/3.42
Re: Coil keeps burning out
I see you havent gotten any suggestions yet?..maybe tell us some more info ..what exactly did you replace when you did the ignition system?.It sounds like you have some wires crossed or missed a few that were supposed to be hooked up?..tell me what does the Olympic edition have that a regular camaro doesnt?
Old 04-24-2008, 10:51 PM
84olmpcboy's Avatar
Engine: 2.8
I put on a new dizzy cap and rotor, ignition molecule, wires+ plugs, and coil. The olympic edition just has the standard v6 in it nothing special. I rechecked my wiring a couple times and i polished the contact points b/c of corruption and they fit up nice.
Old 04-25-2008, 08:41 PM
jstrdn90rs's Avatar
When you put the ignition module in ..did you apply the electric grease between the module and distributor base before you installed it?
Old 04-26-2008, 12:21 AM
project89's Avatar
make sure all the grounds are good, bad grounds will burn up a coil and or ign mod in a hurry
Old 04-28-2008, 08:57 PM
84olmpcboy's Avatar
Engine: 2.8
I checked the grounds and they were all good. I put on the electrical grease that came with the molecule. I checked the spark and it was still yellow, but when i was cranking I saw a spark jump from the alternator to the fender so I'm not sure what that was all about.
Old 04-28-2008, 09:08 PM
project89's Avatar
thats an afully big gap to jump,can that even be possible.i mean ur battery terminals are closer together and they dont arch. u would have to pysically complete the circut across the 2.
take a volt meter and unhook the positive batt cable take the neg lead of the volt metter and conect it to the pos side of the battery, then take the positive lead and connect it to the batter cable see if u get a voltage readin with the doors closed and key off.if u get any reading u have a short somewere
oh btw make sure the hood light is off or it will give a reading,
Old 04-28-2008, 09:12 PM
84olmpcboy's Avatar
Engine: 2.8
ok. Ill have to try that tommorow. Im sure it happened because there was two of us that saw it im just not really sure how it happened. Im thinking that something happened with the alternator and maby it shorted out when that spark shot out of it.
Old 05-02-2008, 09:46 PM
84olmpcboy's Avatar
Engine: 2.8
I did this test and it said that i had a short. I took apart the ignition and traced all the wires going out of the coil for shorts and the ones plugung into the bottom of the distributor. I didnt find any shorts here so i guess the short has to do with something else.
Old 05-02-2008, 11:19 PM
project89's Avatar
what was the voltage reading?
Old 05-06-2008, 07:57 PM
84olmpcboy's Avatar
Engine: 2.8
12.4 with the key off 4.5 with the key on
Fanatic1074
10-03-2022 05:57 AM
RedLeader289
05-28-2019 01:47 PM
school boy
10-22-2015 11:47 AM
92rsvortec350
19
10-09-2015 09:39 AM
Thornburg
Aftermarket Product Review
10-06-2015 12:04 PM
Quick Reply: Coil keeps burning out
