Anything for cleaning/dissolving RTV off intake?
Old 04-13-2008, 06:05 AM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
Today I plan to pull my lower intake off and clean it up good. I didn't originally plan to pull it off, but someone put RTV in the injector bosses, I guess to fix leaking o-rings. The intake was also painted silver (without removing it) and doesn't look all that great. I will probably try soaking it with aircraft stripper, but does anyone know of anything that will eat RTV off? If the stripper doesn't work, then I'll have to spend some time scraping the RTV out of the injector bosses, which doesn't look like much fun.
Old 04-13-2008, 09:11 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
Re: Anything for cleaning/dissolving RTV off intake?
I've never heard of anything that actually cleans it off.
Have fun scraping
Old 04-13-2008, 11:16 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
The only thing that I know of that dissolves RTV is gasoline, petrol, pump gas. . .
RBob.
Old 04-13-2008, 12:50 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
I was pretty sure RTV was typically un effected by gasoline. I RTV'd around my mechnical fuel pump gasket.
Try laquer thinner, MEK or xylene. Those are the strongest solvents I know of.
Old 04-13-2008, 03:52 PM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Yeah, that's what I was afraid of. I guess I can try the dremel with a wire wheel, hopefully that will speed it up a little. Thanks for the replies guys, I figured it was worth a shot
Old 04-13-2008, 07:24 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
If a mechanical fuel pump gasket is exposed to gasoline, the pump is leaking.
RBob.
Old 04-13-2008, 09:44 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am, 92 Firebird
Transmission: TKO600, T5
it says on every tube of RTV ive ever bought that its not for use where immersed in gasoline. Give it a whirl
Old 04-20-2008, 01:27 AM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Just thought I'd update this thread, in case anyone else has the same problem. A dremel wire cup wheel is the perfect size to get into the injector holes and clean them out. It took about 5 minutes to get every last bit of RTV out of there.
Old 04-20-2008, 01:50 PM
Vader's Avatar
So is a bore brush for a 20 Ga. shotgun, or a cleaning brush used for 1/2" copper sweat fittings.
Old 04-20-2008, 03:55 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Use some strong thinner, a VERY sharp new razor, and a lint free rag (shop towels for example), and it should come off fairly easy.
Old 04-20-2008, 08:13 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
I have had some luck with carburetor cleaner. That is with Permatex #2 which is a silicone variety.
customblackbird
10-01-2015 04:30 PM
85 Jimmy
09-30-2015 07:56 AM
Bubbajones_ya
09-14-2015 08:38 PM
toronto formula
09-10-2015 07:31 AM
e3pres
09-09-2015 01:51 PM
Quick Reply: Anything for cleaning/dissolving RTV off intake?
