MACHIAVELLI on craigslist
Location: Doghouse ······································ Car: 1989 Formula 350 Vert Engine: 350 L98 Transmission: 700R4 Axle/Gears: B&W 3.27
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
Re: MACHIAVELLI on craigslist
Honestly I kind of like what they have done with it. I know I am going to get bashed but I always liked Ferrari's and these have a 308 feel to them... I bet they really turn heads going down the road.
JOhn
JOhn
Car: 87 trans am
Axle/Gears: 3.42 SLP rear
Wow, that ferrari is HUGE!!! Heh...
It's weird that the bottom ones have bird ground effects though.
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
Yeah, and adding a couple hundred pounds of bondo and fiberglass definitely won't make it faster...
Car: 80 SE/TTA;88 T/A GTA;86 T/A
Engine: 4.9L Turbo; LT1; empty
Transmission: TH350; T56; empty
Axle/Gears: 3:23 disk; 4:10 disk ; 3.42 disk
means easier to fix if you wreck the sides from sagging doors or going over hills that are too steep?! If someone was to find one of these years from now i'm sure they might be a little happier if they had the capability to find at least some parts easily. Overall i like it, works well with the body, of which i LOVE the stock bodies, but this holds it's own IMO.
John
Now that you mention it, the fit is horrible. The hood looks like it's pop canned. I do like the wood steering wheel and would like to see a good pic of the leather Recaro leather seats.
Dang, I was hoping to see photos of Tupac's third gen.
This car is hideous on so many levels.
1. Most often copied/hacked-up car that they're trying to re-create (Ferrari 308/328, which it doesn't even look close to since the dimensions of the two cars are so different)
2. Waste of a perfectly good T/A
3. It's a gutless LG4
4. Woodgrain kit (WHY!? Ferrari 308s never had woodgrain!)
5. Poor fit and finish
Car: 1988 IROC-Z camaro
Engine: 355 TPI
Transmission: tko 500
Axle/Gears: Dana 44 3.31 posi pbr brakes
Those arnt leather recaros either. They are LS Contour seats. Ill get a slight flame for this but of all the kit cars ive seen based off these cars i like this the best.
No worries... I actually kinda like it too
