454 with hydraulic roller cam????
Old 03-28-2008, 03:54 PM
snowflake's Avatar
Car: 91 camaro
Transmission: auto
Axle/Gears: ????
What year did the 454 come out with the hydraulic roller cam??
A friend of mine has an 88 burb with the 454 but it has the older
style timing cover on it. If I'm correct, the H/R motor has the plactic
timing cover. Anyone know?? THANKS
Old 03-28-2008, 07:50 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Re: 454 with hydraulic roller cam????
I think the Mk V big blocks started around 1990-ish (Mk IV is the old style).
Old 03-28-2008, 08:35 PM
rocko350's Avatar
Car: 1991 caprice / 96 caprice
Engine: 4?? bbc / lt-1
Transmission: 700r4 / 4l60e
Axle/Gears: 4.10/ 3.73
Mk V started late 95 early 96 for the L29 vortec. just like vortec small block. better cam incremental change in compression and roller cam along with sequential injection. ended in 2000 i belive. it was replaced with the Gen III 8.1l
Old 03-28-2008, 08:42 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Gen IV is up to 1990 and is what 99% of all the aftermarket BBC stuff is based on. Mark V L19 is 91 to 95 and still uses flat tappets and was the worst design BBC GM produced. In 96 GM brought out the Gen VI Vortec engine which was a roller block.
Old 03-28-2008, 10:26 PM
Damon's Avatar
Agreed with Stephen on this. Roller cams didn't show up in big blocks until 1996 with the Mark 6 design.
Hotrodboba400
12-10-2019 07:07 PM
Jorlain
10-08-2015 01:57 AM
Nick McCardle
09-10-2015 08:36 PM
Hotrodboba400
09-02-2015 07:28 PM
Quick Reply: 454 with hydraulic roller cam????
