radio keeps turning off and on continuisly while driving
Car: 88 prelude si/91 camaro rs
Engine: 2.0/3.1
Transmission: D2J5/700r4
i just installed my radio today,i used a wiring harness,i butt connected all the wire but for some reason my radio keeps turning off and on while i am driving.can anyone lead me in the right direction on my search???the only thing i can think it is is a short some where in a wire.
thanks and godbless
sincerly
carlos m mesa
thanks and godbless
sincerly
carlos m mesa
Car: 1987 Camaro
Engine: 5.7
Re: radio keeps turning off and on continuisly while driving
Yeah its probally just a loose wire and off and oning on bumps. I had this problem and mine was actually a battery cable, but if it worked ok before im betting on a bad connection or loose wire.
Car: 1988 Trans Am GTA
Engine: 5.7L Ported SLP Runners and Intake
Transmission: 700r4 w/ shift kit
well soldering isnt quite necessary , although it would def. get the job done. but yes, if your previous radio worked fine, and now the one you just installed is cutting out, then its simply a bad connection( i suppose you radio could be bad but lets assume its fine). I would guess its either the power wire or the one that tells your radio to turn on/off when you turn your car on/off.
Car: 84 camaro z28
did you double check all the butt connectors, its probably the ground or power so check those
This is probably not your problem, but I'll throw it out there.
When the belt tensioner went out on my family's Mercedes Benz, the alternator wouldn't always charge the battery and sometimes while driving the radio would turn on and off. When the tensioner was replaced the problem went away.
Again, probably not your problem, just throwing it out there. Maybe something to do with the charging system, but if it checks out, then I'd agree with the other posts. Loose connections.
-zrated57
-zrated57
Engine: 2.0/3.1
im going to try using smaller gauge butt connectors i think the ones i used were to big mhmm,i have a brand new tensioner,alternator and optima battery i doubt its the problem but i will check anyways.
as always thats for the help
carlos mesa
carlos mesa
Car: 1987 Trans Am
Engine: 355ci L98 soon to be turbo'd
Axle/Gears: 2.73 posi
I'd also check the ground, thats always a bitch...
Engine: 2.0/3.1
thats what im thinking it is i am going to run a new ground with a thicker gauge wire to see if it works this weekend.
Car: 84 Trans AM
Engine: 327
Transmission: M5
Also probably not your problem, but when mine did that it was because the power wire came loose from the mount and was grounding to the headers on bumps after the insulation melted.
If the radio gets hot they tend to shut off I had the same problem and I research for days until I found the solution I tried a computer fan at the back and install it to the radio .The cooling system on the radios are very bad trust me so as soon as it get a little hot it shuts off on your drive and it can be very annoying I know
