89 tpi 350 wiring diagram?
Old 03-07-2008, 01:39 PM
MRROCKAPE's Avatar
I just bought a wrecked 1989 tpi camaro with a 350/700r in it.I am going to put the engine/transmission into a 1970 elcamino.
So here is my question....
Where can I find a diagram that will help me make the stock engine/ecu harness work as a stand alone that will be swapped into the elcamino??
I am proficient at wiring,but want a good write-up or diagram since the mitchel on demand one lacks in ease to read and follow.......
Thanks in advance and if this has been covered please direct me to a link and I will delete this thread.
Also is there any adverse effects of swapping a set of headers(with an o2 bung)and losing all of the air injedction???Things I should watch out for??
Old 03-07-2008, 02:20 PM
Wadebryant's Avatar
Car: 87IROC, 740iBMW, 328iBMW, 86GMC
Engine: 5.7, 4.4LV8, 2.8, 6.0
Transmission: Manuals & Auto's
Axle/Gears: 3.27, 3.42
Re: 89 tpi 350 wiring diagram?
All kinds TPI of info here: http://www.chevythunder.com
Good luck
Old 03-08-2008, 10:04 AM
MRROCKAPE's Avatar
Good luck
Thanks thats a great resource!!!But does anyone have the pin-out for the drivers side firewall connector??Everything else looks plug and play.
Also where is a good resource for a speed sensor that goes in-line with the speedo cable at the transmission??
Last question....Am I gonna need to use a custom burned chip to eliminate the factory anti-theft??
camaro11j
09-19-2018 08:49 AM
Infested
05-22-2018 11:56 PM
Caspar
06-19-2016 11:19 PM
st.evel07
08-13-2015 06:15 PM
Sanjay
08-12-2015 03:41 PM
Quick Reply: 89 tpi 350 wiring diagram?
