Does a fan relay switch ground through the switch?
Old 03-07-2008, 01:38 AM
thepoz89's Avatar
Car: 89 Firebird 89 Formula one red one black
Engine: 350, 355
I am trying to fabricate something to turn on and off an electric fan, and am wondering if the fan relay switch grounds through the switch. I would like to connect a switch up to a 12V constant and use the switch to cool the engine. The switch is out of an 86 TA. Is there anything else to consider? Thanks for your help...
Old 03-07-2008, 07:20 AM
Trick414's Avatar
Car: 1991 RS Vert
Engine: LO3, 305, TBI
Re: Does a fan relay switch ground through the switch?
A relay can be wired to switch either side of a circuit.
I'm not exactly sure what you are trying to do here, but I'll take a stab at it.
You don't need a relay if your switch is going to have 12V+ on it. Just run the 12V+ from the switch to the fan. Make sure to use appropriate size wire and fuse.
Old 03-07-2008, 08:08 AM
Wadebryant's Avatar
Car: 87IROC, 740iBMW, 328iBMW, 86GMC
Engine: 5.7, 4.4LV8, 2.8, 6.0
Transmission: Manuals & Auto's
Axle/Gears: 3.27, 3.42
Open the attached thread. Then, scroll down to the bottom of the product listing, you'll see Wiring harness Instructions. Click on that. It'll open and show you a wiring diagram. When I wired in my switch and relays, I found it very handy.
http://store.summitracing.com/partde...5&autoview=sku
Old 03-07-2008, 09:27 AM
naf
naf's Avatar
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
You can use the stock fan relay. The relay control is a ground lead that, in stock form, grounds thru the temp switch or AC pressure switch. No reason you couldn't run this same ground lead through a manual switch.
You do not want to run your primary fan power through a switch. The amp draw will require more expensive wire and a heavier duty switch. Even if you buy a new stock style relay it will only run around $15 or so.
Old 03-07-2008, 11:09 AM
thepoz89's Avatar
Engine: 350, 355
Ok, here is what I am thinking, I have an older Chevy from the 1950s with a hole in the head that looks like I could take a fan relay switch/sensor and bolt it in and get rid of the manual fan and use an electric fan. I want to use the sensor to control the on/off of the fan.
I think I could use this but am not sure of how to wire it. If the switch grounds through the head, then I should have no problem just hooking up a constant power source and letting the switch do its work.
Old 03-07-2008, 12:08 PM
naf
naf's Avatar
The switch should ground through the head but you MUST run the primary power to the fan through a relay. Putting that many amps through the sensor to the head is a bad idea.
Check a wiring diagram for any third gen and trace the fan motor power and control wiring. Pretty simple AND easy.
Old 03-07-2008, 12:13 PM
thepoz89's Avatar
Engine: 350, 355
so i do need a relay. thanks for your help!
Old 03-07-2008, 12:31 PM
naf
naf's Avatar
Yeah, you can pull a relay off at a JY for next to nothing or buy a replacement relay at AZ or the equivalent for around $15. Best to hit the JY though as you'll need the four-plug pigtail for it or have to fashion one.
The single fan assembly from a JY with associated shroud, wiring, pigtails and sensor will work fine for a mild performance engine. If you need it all, best to pull it all at once and replace the wiring with new and the fan motor, if needed.
Old 03-07-2008, 12:35 PM
thepoz89's Avatar
Engine: 350, 355
Thanks again for the follow up, I am gonna try to do this before summer.
Ghettobird52
12-29-2023 08:23 AM
GTAman
03-15-2019 11:40 AM
krisner89
10-10-2015 06:03 AM
soarestransam
09-01-2015 04:00 PM
eightsixseven
08-14-2015 03:09 PM
Quick Reply: Does a fan relay switch ground through the switch?
