TPI cleaning?
Old 02-02-2008, 04:09 PM
BrOdBaNd's Avatar
Car: 92 Camaro
Engine: El Tee Juan
Transmission: Tee five six
Axle/Gears: 10 Bolt 4:10's
TPI cleaning?
I just got a TPI setup and I really want to clean it up before I put it no... Whats the safest way to go about cleanin this sucker up... Gettin all the corrosion and whatnot off
Old 02-02-2008, 04:22 PM
87SSTPI's Avatar
Car: 1987 Monte Carlo SS
Engine: Vortec headed 350
Transmission: '89 WC T5
Re: TPI cleaning?
I'm kinda new to the TPI stuff also. After I got it I took it to work and carefully sandblasted everything except for the fuel rail and throttlebody(I covered all of the holes before sandblastingthe intake and plenum-NOT the runners-I only sandblasted the lower intake and plenum). My runners I took a 3M Roloc disc to then polished with SOS pads from the grocery store. PLEASE keep in mind I am not claiming to be an expert at ANYTHING, but I AM thrilled with how mine came out and it is EXACTLY the look I wanted.
Click on the "vB garage" down next to my online status to see some pics.
Old 02-07-2008, 11:49 AM
BC GTA's Avatar
Car: 1989 GTA
Engine: 5.0 TPI
Transmission: T-5 WC
Axle/Gears: Yukon 3.73
Re: TPI cleaning?
Well I recently had mine disassembled to install new injectors and an AFPR and all the parts were cleaned in my mechanics parts cleaner. Some times took 2 washings. Do not put the TPI throttle body plate in the cleaner as it took some of the original paint off. If I had them at home I might have soaked them in solvent. You mentioned corrosion most of the TPI system is aluminimum which does not rust. I used Mothers mag polish to brighten everything up before it was put back on.
Old 02-07-2008, 02:35 PM
89transam*pearl's Avatar
Car: 89 T/A
Engine: LB9
Transmission: W/C T-5
Axle/Gears: 10 bolt posi, 3.73 Richmond Gears
Re: TPI cleaning?
Do a search on polishing the plenum.
There's some really good threads and all you really need is a drill,palm sander and about 8 different grits of sand paper to achieve an almost mirror finish.
Old 02-07-2008, 04:01 PM
Mongoose's Avatar
Car: 90 Formula
Axle/Gears: 9 bolt/3.27
Re: TPI cleaning?
I used glass beads in a blast cabinet to clean mine up and then painted it in high temp aluminum (500 degree) which is a perfect color match for the bare aluminum. I then sprayed it with clear(500 degree too) and it looks like a brand new TPI all the time.
Old 02-07-2008, 04:54 PM
gearhead0384's Avatar
Car: 1989 Camaro IROC-Z
Engine: L98 350 TPI
Transmission: Built TH-700 R4 (Vilgilante 2800)
Axle/Gears: 9 bolt w/ PBR's
Re: TPI cleaning?
When I pulled my engine I cleaned the Plenum and Runners with fine steel wool and it came out great the runners especially.
Kevin
Orr89RocZ
04-25-2016 08:28 AM
69 Six Pack
10-05-2015 07:51 PM
mdtoren
08-16-2015 05:45 PM
Sanjay
08-12-2015 03:41 PM
Quick Reply: TPI cleaning?
