Looking for 9" Ford Rear End
Old 01-26-2008, 10:06 AM
Bob Brown's Avatar
Car: Red T-Top 89 IROCZ
Engine: 400 / punched out 30
Transmission: 700R4 / 3500 stall
Axle/Gears: Ford 9" 390 gears
Does anyone have a 9" Ford Rear end for sale? Or do you know which Ford car has the best rear end size for the 89 IrocZ?
Old 01-26-2008, 10:14 AM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: Looking for 9" Ford Rear End
Because of the third gen's torque arm suspension, there is no Ford factory differential that is a direct bolt in. Unless you plan on changing the rear suspension design, your best bet is to buy an aftermarket 9" designed to be a bolt in for a third gen.
My first junkyard 9" was out of a 1970 F100 but I installed ladder bars to eliminate the torque arm.
Old 01-26-2008, 10:43 AM
Bob Brown's Avatar
Thanks for getting back, I have a welder and was planning on doing a little welding to make it fit, but was unclear on the best ford axle to get. You think a 1970 F100 would be the best fit??. I have a 405 short block with a new 700r4 trans. what gears do you think will work best.
Old 01-26-2008, 12:08 PM
AlkyIROC's Avatar
Car: 87 IROC L98
The F100 differential is very close to the same width as a third gen but the pinion isn't centered. It's offset to the passenger side about 2" making both axle shafts the same length. A car diff like from an early Cougar or Mustang is a better choice. You'll also need to change the axles or have the wheel studs redrilled to a more common size. Ford truck bolt pattern is very big. I had aftermarket axles with the Ford 5 on 4-1/2 bolt pattern to easily use a Ford drum brake system. At the time, I was using Weld Draglite rims which have Ford and Chev bolt pattern.
With a 700R4 I wouldn't want anything deeper than about 3.55 gears. The 700's low first gear doesn't need a deep gear in the diff.
There's a lot more to using a junkyard diff than the width. You have to change over all the suspension mounting hardware from a third gen diff to the junkyard diff such as shock and spring mounts and the panhard bar mount. As I've already mentioned, there's no easy way to attach a torque arm. When I installed ladder bars, the front ladder bar mount is inside the car so I had to modify the floor. Then there's the brake system that needs to be addressed including park brake cable if you choose to use a park brake. Wheel bolt patterns since you can't put Chev rims on a Ford bolt pattern. You'll need a combination u-joint to hook up the driveshaft and "may" need a different length driveshaft.
By the time you're done fabricating and modifying, it can be cheaper to just buy an aftermarket bolt in diff.
Old 01-26-2008, 12:19 PM
camarokev400's Avatar
i used the junkyard 9 inch and had all the brackets cut off my 10 bolt and re-welded onto the 9 inch housing. I had it done though so i couldnt really tell you how hard it was, i know the guy that did had a jig built just for doing it, he also narrowed the housing, its slightly shorter than the stock 3rd gen housing. I bought a fully adjustable weld on torque arm mount from some company out of pennyslvania, i would have to look for the name of the place but have pics if you want or need them. I got an adjustable panard bar, and i havent yet ordered my axles thats next on the list. But i am using the ford explorer rear disc brake setup off ebay for 150 bucks.
Old 01-28-2008, 08:19 PM
Bob Brown's Avatar
Can anyone tell me if a 84 trans. rear end bolt up to my 89 IROCZ and do all the 84 Trans come stock 3,73 and posi.
Old 01-28-2008, 08:38 PM
Received 1,664 Likes on 1,262 Posts
Yes. No. No.
Old 02-12-2008, 08:51 PM
there are pictures of that torque arm mount i was talking about on this thread, im selling all my stuff and buying the bolt in housing. I gave up on trying to fab this one up the hard part is done already but i just dont want to mess with welding on the torque arm and trying to get all the angles right.
https://www.thirdgen.org/forums/engi...ing-needs.html
hectre13
12-11-2023 08:14 AM
hectre13
08-26-2015 08:17 AM
AkDrifted
08-17-2015 07:45 PM
Jlanz55
08-17-2015 07:15 AM
BlackBoulder
08-11-2015 11:15 PM
Quick Reply: Looking for 9" Ford Rear End
