FOR SALE 5.3 SHORT BLOCK
Old 01-21-2008, 03:08 PM
badnova's Avatar
I have a nice 5.3 short block crank rods pistons and steel block in very good condition also aluminum oil pan and windage tray 250 firm has less that 50k miles no cam thats what went bad so person wanted to change whole engine nothing wrong with this one in so fla
Old 01-21-2008, 03:14 PM
BLACK ICE's Avatar
Car: 91 RS
Axle/Gears: 10 bolt
Re: FOR SALE 5.3 SHORT BLOCK
Just curious what is a 5.3? 396?
Old 01-21-2008, 03:24 PM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
5.3=lsX series motor from full size chevy pickup truck. it's like 330+/- cubes.
what exactly went bad on the cam? wipe out any cam bearings? iron or aluminum block?
Old 01-21-2008, 04:45 PM
badnova's Avatar
5.3 equates to approx 347 cubic inches No bearings are bad lobe went down its iron block in nice condition with pan and windage tray
Old 01-21-2008, 04:53 PM
jamez74's Avatar
Car: 1990 GTA
Engine: 350 LT1
Axle/Gears: 3.70
5.3 = 327 doesn't it?
Old 01-21-2008, 05:16 PM
phillip_helmet's Avatar
Car: '84 Camaro
Engine: 5.3l TSP 224r
Transmission: TH350 3600 stall
Axle/Gears: LS1 3.23
I'm pretty sure a 5.3l is 323cid
Old 02-01-2008, 06:54 PM
badnova's Avatar
my bad 327 is what it equates to
Old 02-01-2008, 07:10 PM
TIMMYS89GTA's Avatar
Car: 81z-28,89gta,91z-28 03 1500
Engine: 355,L98vette tpi,327
Transmission: TH350/700R4/700r4/4l80E
Axle/Gears: 3;73/3;27/2;73/3;73
yeah,323!
thats the same engine in my 03 silverado.
badnova,where in Fl. are you located exactly?
Old 02-01-2008, 07:29 PM
WIll36's Avatar
Car: 88IROC, 91Z28 + parts cars
Engine: 355, 408
Axle/Gears: 3.42 LS1, 9" w/ 4.56 and spool
actually the gen 3 and 4 5.3 truck motors measure out to 325 cubic inches.
Old 02-02-2008, 01:16 AM
nomad88z's Avatar
Yes, a 5.3 is 325 ci, although the 5.7 lsx and 5.3 are the same block, so the 5.3 can be bored over to 5.7 unlike the 5.0 and 5.7 gm gen 1 blocks. Just as a reference, 1 liter is approximately 61 cubic inches.
what year is the motor, does it have the Lq9 (taller) intake on it? accessories?
Old 02-02-2008, 07:37 AM
badnova's Avatar
east coast port st lucie just above west palm beach
short block means it has no heads But I do have an intake for additional $$$ and it is truck intake complete with injectors and throttle body fuel rails etc
Old 02-02-2008, 11:18 AM
1991CamaroRslow's Avatar
Car: 1991 L03 700r4 RS
Engine: 1987 WS6 Trans AM Lb2
Transmission: Th350 red neck Performance 3k stall
Axle/Gears: 95 Mustang 8.8 built with 3.73s
Not to thread jack or undercut but I have a set of good 5.3 heads, and a tall truck intake, complete with injectors if someone's interested in them for this short block.
Old 02-02-2008, 11:44 AM
THIRDGEN87's Avatar
Car: 87 FIREBIRD / 89 TRANS AM GTA
Engine: Ls1 / 350 L98 TPI
Transmission: 4l60e / 700R4
Axle/Gears: 3.73 / 3.27
read the april 08 issue of car craft on the 5.3 100+hp with just a cam swap!!!!
Old 02-02-2008, 12:12 PM
WIll36's Avatar
Engine: 355, 408
yeah the block is the same the difference is the cylinder sleeve actually. If you want some good info on these motors autozone has a great book on gen 3 motors and possible cam, head intake combos for 20 bucks. But you have to be careful when you bore the motors cause the high density steal sleeve is very thin on an LS1(can only bore about 1mm). So not to jack the thread or bash on the sale just be warry these aren't like older SBCs where u can punch them up to 60 over with out much problem. But with the better angle on the valves you can make a lot more power with fewer cubic inches. And get reasonable fuel milage at the same time.
Old 02-02-2008, 06:57 PM
badnova's Avatar
your right on ls1 blocks BUT lq9 is a truck block and steel which is good for turbo or super charging plus steel blocks are alot stronger than aluminum cousin I'm building an lq9 steel block for turbo just with heads and cam easy 450-500 hp without turbo with a carb on it these new engines are something else compaired to old small blocks new cylinderheads out flow old three times better than a good old style head
Old 02-03-2008, 01:01 AM
soultron's Avatar
Car: 87 trans am
Axle/Gears: 3.42 SLP rear
april 08?
Old 02-03-2008, 09:44 AM
jamez74's Avatar
Car: 1990 GTA
Engine: 350 LT1
Axle/Gears: 3.70
What cam was it do you remember? I might have to look into that for my silverado.
Old 02-03-2008, 09:35 PM
xxvictimxx26's Avatar
Car: 84' T/A
Engine: 5.3
Transmission: th350
Axle/Gears: 4.56
still for sale?
theshackle
03-05-2017 06:37 PM
anesthes
03-10-2016 10:35 PM
Reddeath210
10-06-2015 08:20 AM
camaro71633
09-01-2015 10:24 AM
BBSDesigns
08-11-2015 07:39 PM
Quick Reply: FOR SALE 5.3 SHORT BLOCK
