car makes air loss noise
Old 12-10-2007, 03:22 PM
billybob6110's Avatar
Car: 1984 chevy camaro
Transmission: turbo 350 2800 stall
Axle/Gears: 3:73 detroit locker posi
car makes air loss noise after i sut the car down. did cam replacement and torqued to the specs. any ideas?
Old 12-10-2007, 03:23 PM
afida15's Avatar
Re: car makes air loss noise
does it make like a HISSINg sound? if it does its a Vaccumn leak somewhere prob
Old 12-10-2007, 03:30 PM
its note a hissing its real quick like 5 seconds after car shut down.. i rechecked and rechecked everything. sounds like comming from motor
Old 12-10-2007, 04:55 PM
can i possibly be a valve stickn open or closed? by to tight on rocker arm?
Old 06-08-2009, 11:07 PM
mcbchild's Avatar
Car: 1984 Firebird SE
Engine: 388 sbc, Brodix Track 1s
Transmission: turbo 350 transmission
Axle/Gears: 4.10 gears
I am having this same sound and wondering what that is. It only comes on after the engine is just turned off and is about 5 sec. on the passengers side of the engine. I did have the heads milled down to 63 cc from 65 and not the intake. Could it be pressure being released after the engine is turned off and a bad seal from the intake not seated and leaking from the intake gasket?
Will do a compression test tomorrow.
Old 06-10-2009, 12:19 AM
mcbchild's Avatar
I discovered that the pressure release sound after shutting of the engine was actually the back plate gasket on my water pump was leaking. Problem solved.
B_Dubya
08-26-2015 05:09 PM
BlackBoulder
08-11-2015 11:15 PM
mustangman65_79
08-11-2015 03:17 PM
bryan623
08-10-2015 11:33 AM
Quick Reply: car makes air loss noise
