New AFR 195 heads #1034's
Old 11-15-2007, 12:26 PM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Be very wary of these heads and there fitment.
I have just installed two sets of these and they do have problems.
All the bolt holes are too shallow, and will require shimming and washers.
AFR claims to have taken care of this but maybe not (I have two sets that aren't).
The machining for the valve covers is wrong on the center bolt type. They are machined too narrow and the valve covers will leak.
I have 12 different valve covers at my disposal and only two will fit these heads. Of course I found this out AFTER installing them in the car.
And as usual AFR claims to have no knowledge of this.
They do mention you have to cut the bolts off, (in their directions) to keep them from bottoming out, which I did, but did not notice they were not fitting down in the heads. The inside lip of the cover hits the rail, preventing the gasket from making contact with the head.
Old 11-15-2007, 12:33 PM
Guest
Guest
Posts: n/a
Re: New AFR 195 heads #1034's
More fine AFR quality.
Old 11-15-2007, 02:53 PM
Burnout91's Avatar
Car: '91 Z28 L98 G92
Engine: Modded L98
Transmission: Modded 700R4
Axle/Gears: Modded 10-Bolt
Yep, I asked the sales rep, and the engineer / manager Tony Mamo, if they had corrected the shallow bolt hole problem BEFORE I placed the order for my 1034s. I was told that they were aware of the problem with past heads, but the problem had been corrected. Then I called to inform them of the valve cover fitment issuse (s) Don had encountered during the installation (have we found all of the problems yet??). Sales rep had no knowledge of the problem. The AFR website states "no special parts required", total bolt on. I plan to make AFR quite aware of the meaning of "truth in advertising". Bill
Old 11-15-2007, 05:52 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
Yep, I saw it first hand today. For AFR it would be a simple computer program change on their CNC milling operation to correct the problem(s).
Old 11-15-2007, 07:44 PM
Burnout91's Avatar
Engine: Modded L98
....they do, however, seem to make some power. Bill
Old 11-15-2007, 11:53 PM
antoine's Avatar
Car: 1988 camaro z28,1997 camaro lt1
Engine: 355 afr 195 heads,tpis big mouth
Transmission: 700r-4 built by me 3-4 z pack
I have them same afr heads and i have valve cover problems and i have broken two screw in studs,both at the rocker arm nut.
Old 11-16-2007, 11:24 PM
LilJayV10's Avatar
Car: 89' T/A, 00' Firehawk
Engine: 406 Roller
Axle/Gears: 3.23 Posi
I just ordered a set a few weeks ago. I ordered the 1140's i think. We will see. You spend that much on something, it should be right.
Old 11-20-2007, 10:51 AM
Burnout91's Avatar
Engine: Modded L98
I called AFR and spoke to a sales rep on Nov. 15 to let him know about the issues with valve cover fit and bolt hole depth. He said nothing in the design of the casting had been changed recently, so it wouldn't do any good for AFR to send me new heads. I told him I thought it was unreasonable to have to remove and replace the heads, and that AFR should pop for a set of valve covers that fit their heads. I haven't gotten a return call from them yet (no surprise there...), but I will call AFR today to remind them that they have an issue that must be addressed.
Bill
Old 11-20-2007, 08:57 PM
LilJayV10's Avatar
Engine: 406 Roller
So is there going to be a problem with the perimeter type valve covers?
Old 11-20-2007, 11:11 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
there are more available rockers for perimeter style valve covers and more perimeter valve covers available i dont know why you would want centerbolt stuff. narrowbody full roller rockers are generally more expensive than regular rockers
i'd just use the other old style parts but thats just me. STILL tho for heads that expensive and thought to be the "G0D" of all heads, i'd expect 99.9% quality
Old 11-20-2007, 11:42 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Our newer cars came with centerbolt valve covers, and I feel centerbolt valve covers look better.
Also, nothing screams "engine change" and sounds the alarm to the smog guys here in CA more than aftermarket valve covers.
Old 11-20-2007, 11:49 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
well its dissappointing you california guys have such strict smog laws. Either way there shouldnt be issues with mounting either valve cover
Old 11-21-2007, 12:37 AM
LilJayV10's Avatar
Engine: 406 Roller
They are not that much more expensive than a trick flow or a brodix head. With the eliminator series they fixed a lot of things that added extra costs before; valve springs, drilled for coolant holes. I agree though, they still aren't cheap and you would think they could fix some of these problems.
I don't like perimeter type valve covers anyway. Luckily I don't have to use them.
Old 11-21-2007, 11:42 AM
Guest
Guest
Posts: n/a
Its just a typical aftermarket part issue. I have yet to find one without flaws or that fits right. I just cant figure out how they made a mistake like that because AFAIK there isnt anything wrong with the valve cover rail locations on their old heads and there are plenty of SBC heads laying around to measure and verify.
Hey at least you know they didnt use any of the old casting on the new eliminator heads.
Old 12-17-2007, 02:29 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
well i plan to order AFR 1040's very soon, sometime this week actually if not today.
i hope i dont run into any issues. I also am trying to get them flowbenched around here to see what the numbers look like
Old 03-11-2013, 10:07 PM
maks10's Avatar
Car: 1990 Trans Am
Engine: 5.7 350 HSR afr195 xfi268
Axle/Gears: 3.08 posi
so im not the only one with this problem...looks like old news for everyone but i just found out fitment issues...acc holes and valve cover holes not tapped far enough....they still havent fixed this and its 2013
and AFR is not to kind to help correct this situation either...just FYI for others.....way too expensive product for this to be and it looks like others have mentioned this to them and they havent changed this????
Old 03-12-2013, 03:05 PM
robg91z's Avatar
Car: 1991 Camaro Z28
Engine: 350ci TPI
Transmission: built 700r4
Axle/Gears: 4th gen rear end
I emailed them about their heads and some other products they have on their website that im interested for my build and i have gotten no response. What did everyone do in order to fox these problems? Did you guys send the heads back?
Old 03-15-2013, 07:27 AM
maks10's Avatar
Car: 1990 Trans Am
so far extra washers,etc....havent tested out valve cover seal just yet(using centerbolt)...hopefully no leaking...waiting on stealth ram to come in...
my heads where mounted so had no intention on sending mine back unless huge problems came about but just wanted them to note this for future products. The guy i spoke with basically said so??? whats the big deal??? not ill take note or say something about fixing them??? a small fix by tapping holes deeper and checking valve cover seal...especially at their price
Old 03-15-2013, 02:20 PM
robg91z's Avatar
Engine: 350ci TPI
Wow well thanks for the heads up i will probably end up going with some dart heads instead ive been hearing good things and i gave them a call and recommended me the 180cc heads for my build so hopefully theres no problem
Old 03-15-2013, 03:21 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Call afr and talk to them. Thats the best way. Better yet talk to Tony Mamo himself. He frequents alot of tech boards, like ls1tech, corvetteforum, speedtalk, etc. he will make it right.
My heads back in 08 did not have these issues
Old 03-15-2013, 03:26 PM
UnderCover89TBI's Avatar
Engine: gone
Transmission: gone
Axle/Gears: gone
yeah how discouraging I may go with a set of the dart heads that they just released.
Old 03-17-2013, 07:52 PM
maks10's Avatar
Car: 1990 Trans Am
ask around...im still finishing my engine up so havent used my afr's yet...just ran into some issues...figured id share this hopefully 5 yrs from now they MAY fix it just to get closer to perfection...they have good reviews and orr can probably vouch his knowledge/experience with them
Old 03-17-2013, 07:57 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Afr has usually been very good with customer service, if there is an issue let Tony know and they will resolve it.
Old 03-29-2013, 07:58 PM
TGO Supporter/Moderator
anesthes's Avatar
Car: '88 Formula, '94 Corvette, '95 Bird
Engine: LC9, 355" LT1, LT1
Transmission: T5, Zf6, 4L60E
Axle/Gears: 3.42, Dana44 3.45, 3.23
Don't know why some people have trouble with this stuff. Never had a problem. Have run a bunch of sets of AFR heads.
-- Joe
Old 03-29-2013, 08:18 PM
conlinj's Avatar
I bought my AFR heads (912) about a year ago, no problems with them here.
norcalz28
Northern California
26
12-07-2016 12:49 PM
92projectcamaro
01-18-2016 08:00 AM
New2Chevy
09-28-2015 12:35 AM
z28guy134
09-01-2015 11:50 PM
Quick Reply: New AFR 195 heads #1034's
