How to tell if i have a 350 or 305
Old 09-30-2007, 01:25 PM
berlincam86's Avatar
Car: 1992 Z28
Engine: 350 tpi
Is there any way i can tell the 2 apart besides taking it apart? I got this car used and i was told the 305 was replaced with a 350 but how can i be sure he is not lying?
Old 09-30-2007, 01:52 PM
Blue_Thunder's Avatar
Car: 1986 Chevy Iroc-Z28
Engine: 1989 TPI 350
Axle/Gears: stock 10 bolt with 2.73 gears
Re: How to tell if i have a 350 or 305
Find the Engine RPO Code that will tell you the year and engine size.
Old 09-30-2007, 02:19 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Axle/Gears: 3.54 Dana 44
The RPO will only tell what was in it originally. Check the casting numbers on the block to find out what it is now.
Old 09-30-2007, 03:43 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Suffix number on the pad in front of the passenger side head or the casting number behind the driver side head. The suffix number is usually hard to read. If the block was ever decked, the suffix number will be gone.
Since the 305 and 350 use different bores, a casting number can easily tell if the block is for a 305 or 350.
Old 09-30-2007, 04:50 PM
Car: 1992 Z28
Engine: 350 tpi
all i can make out on the pad behind the drivers side head is the GM logo and 5G does that tell me anything? I was told that it was replaced with a 350ci gm goodwrench truck engine.
Old 09-30-2007, 05:18 PM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
In that case I would just pull the valvecovers and look at the casting number on the heads.
Old 09-30-2007, 06:33 PM
SpitotRs305's Avatar
Car: 91 RS
Engine: 350 vortec
Axle/Gears: not the best not the worst
i would be willing to bet that the 5G you are seeing is really 5.0... the thing with casting numbers is that you really have to have them super clean and even then some digits can take some creative guessing... but on a relativly new engine it should be pretty clean back there so you should look for a string of numbers further outboard of the 5G you saw
Old 09-30-2007, 07:15 PM
THIRDGEN87's Avatar
Car: 87 FIREBIRD / 89 TRANS AM GTA
Engine: Ls1 / 350 L98 TPI
Transmission: 4l60e / 700R4
Axle/Gears: 3.73 / 3.27
i agree. youprobably looked on the driverside. the casting should be on the passenger side. you may have to use a rag+mirror to get a good look. as it is stamped in. it should contain 8-10 numbers. that way if it is a 305 (5.0) you will know what it is model wise.
Old 10-01-2007, 12:32 PM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
Refer to this link for casting number location.. http://www.mortec.com/location.htm
Old 10-01-2007, 08:23 PM
Car: 1992 Z28
Engine: 350 tpi
Ok its confirmed it IS a 5.7L. I found that out behind the drivers side head next to the big GM stamp it said 5.7L. The 5g i saw before was actually SGI. so what would the date be? I read the link that 89rspower gave me but there is no way i will be able to see them numbers. Im just looking for a general idea what year it could be. This engine does have centerbolt valve covers so its a newer block. Also, I was told that the computer and tbi unit was not replaced with 350 stuff how does this run using a 305 computer and throttle body? i know it really doesnt have the power it should but should it be running with a 305 computer and throttle body? Also what would i have to change? Could i just change the fuel injectors and prom in the computer or should i replace the whole throttle body and computer? One more thing is there anything else i should replace?
Old 10-01-2007, 09:03 PM
Apeiron's Avatar
Engine: 383 Carb
If it has the 5.7 cast on it, then it's a roller block.
Old 10-01-2007, 09:05 PM
Car: 1992 Z28
Engine: 350 tpi
what year did they start making the 350 a roller block?
Old 10-01-2007, 09:06 PM
five7kid's Avatar
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
1987.
Apeiron's Avatar
Engine: 383 Carb
1986
Old 10-01-2007, 09:07 PM
five7kid's Avatar
Engine: LS1/LQ4
Model year 1987 (which began production in 1986).
Old 10-01-2007, 11:56 PM
84z28h.o.'s Avatar
I was told the same, when I bought my Z28 that it was a 350 engine but I don't know. I think it is just stock 305. It is an 87....
Old 10-02-2007, 12:27 AM
five7kid's Avatar
Engine: LS1/LQ4
350's were all TPI from the factory.
Old 10-02-2007, 12:35 AM
84z28h.o.'s Avatar
Mine is carbureted. So I'm assuming it is the LG4...at least, that is what I gathered by the VIN#
Old 10-02-2007, 06:04 AM
Car: 1992 Z28
Engine: 350 tpi
This is a GM truck replacement motor and i cant find one that has a roller cam.
Old 10-02-2007, 11:31 AM
Apeiron's Avatar
Engine: 383 Carb
Doesn't mean it's not a roller block, though.
Old 10-02-2007, 02:34 PM
antman89iroc's Avatar
Car: 89 IROC
Engine: 6.8 HSR N2O
Transmission: TKO 600
Axle/Gears: 9" Moser 3.50 True trac
Well you've found the casting numbers but just to make sure I'd try mashing the skinny petal on the right. If the car fishtails... it's a 350.
Old 10-02-2007, 04:15 PM
Car: 1992 Z28
Engine: 350 tpi
its definetly not fast as it should be and im pretty sure its because of the 305 throttle body and computer. I still havent gotten an answer from that post.
Old 10-02-2007, 04:20 PM
Car: 91 RS
Engine: 350 vortec
on second thought it is a carb... i thought those could pretty much adapt
Old 10-02-2007, 04:25 PM
Car: 1992 Z28
Engine: 350 tpi
im just thinking the computer is not giving it enough gas as it should be for a 350.
Old 10-03-2007, 09:26 PM
Rick)Rox's Avatar
Did both the 305 and 350 come with the TPI?
Old 10-03-2007, 09:30 PM
Apeiron's Avatar
Engine: 383 Carb
Yes, the 305 LB9 and 350 L98 are both TPI.
Old 10-03-2007, 09:46 PM
mjsmikey's Avatar
Car: 89 Firebird Formula **MODIFIED**
Engine: 330 HP Crate 350
Transmission: 700R4 with Shift Kit
Easy way to tell if you have a 305 or a 350 from that year.
Hit the gas...
I can attest to this because I actually did the motor swap. 350s really have more power, especailly above the 3000 RPM mark. Mine Dyno'd at 330 HP.
Old 10-04-2007, 09:27 PM
Car: 1992 Z28
Engine: 350 tpi
Ok guys thanks for your help but i actually sold the car that i was having problems with not because of the problem but because i wanted another car. Thanks alot for all the help i learned alot.
xkingcodex
02-12-2020 07:43 PM
Jake_92RS
01-28-2020 10:37 PM
Dwayne614
09-28-2015 08:33 AM
theurge
08-21-2015 12:46 PM
st.evel07
08-13-2015 06:15 PM
Quick Reply: How to tell if i have a 350 or 305
