Where is the 'set timing connector'?
Old 07-28-2007, 06:14 PM
GTA Jim's Avatar
Car: 1990 GTA
Engine: 5.7
Axle/Gears: 3.27 Posi
Where is this set timing connector? I want to check the base timing of my L98, but I can't find any such connector in the wiring coming from the distributor or anywhere else around the firewall.
Old 07-28-2007, 07:06 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Re: Where is the 'set timing connector'?
on my 89 its a single wire, black and tan behind the passenger side strut tower towards the windshield. its a single wire and single connector. its really easy to spot.
Old 07-28-2007, 08:52 PM
vwdave's Avatar
On mine with the painless harness its about 1' away from the ECU.
Old 07-29-2007, 12:25 PM
GTA Jim's Avatar
Car: 1990 GTA
Engine: 5.7
Yea, there it is... Can't miss it if you know where to look... I've had the car for 11 years and never really noticed it there before In the diagram they show it going directly to the ignition module.. Because of that, I assumed it was near the distributor like in vwdave's painless wiring harness.
Thanks.
Frozer!!!
01-19-2024 04:55 PM
specialized
06-18-2022 09:26 AM
Andrew6.688
12-13-2015 10:59 AM
perZ
08-15-2015 01:17 PM
eightsixseven
08-14-2015 03:09 PM
Quick Reply: Where is the 'set timing connector'?
