rebuilding a quadrajet
Old 07-02-2007, 01:39 PM
dc_sniper9130's Avatar
Car: '84 Camaro SC
Engine: Swapping in a 305
Transmission: 700-R4
Axle/Gears: 3.23 One-Wheel Sqealer
i pulled a 305 out of an 85 caprice classic, and am rebuilding the stock carb. it's the rochester quadrajet, but i cant figure out how to tell which rebuild kit to order for it and believe it or not the chilton manual actually turned out to be useless for me this time. I'm pretty sure it's the E4ME though. also, the top of the pistons told me this was running rich. how do i lean it out? which screw is it?
thanks for any help
Old 07-02-2007, 01:51 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
Re: rebuilding a quadrajet
if its the computer one still then yea its the E4ME
all you need is the stamping numbers off the side of the carb for the auto parts store to get you the kit
its really simple and easy
and the carbs are real simple and straightforward to disassemble
the hardest part really is punching the roll pin far enough to get the accelerator pump arm off, and also reinstalling the primary needles and hanger and piston
it is real tricky lining them up down through the phenoly spacer holes
these carbs are really simple otherwise
the kit comes with exploded view diagram and listing of all the parts names
all you need are the stamping numbers off the carb
search google, as there are lots of pics and pages of info out there on these carbs,and pagesof modifications and improvements too
but more can be found in Q Jet books published by a couple different authors, local library may have one possibly
but ive never used any manuals or books, i learned by grabbing tools and taking it apart, done tons of them now, most turn out fine, but some wont, and some have worn out throttle shaft bushings and require a press to replace them
if you dont then youll have a vacuum leak it wont run right if the shaft is sloppy
good luck
Old 07-02-2007, 01:52 PM
Car: '84 Camaro SC
thanks man. i was also wondering how to lean it out... all the chilton told me was to leave it to a licensed professional. which screw would be the one i want?
thanks
Old 07-02-2007, 01:59 PM
five7kid's Avatar
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
For the rebuild: Check out the sticky https://www.thirdgen.org/forums/carb...e-rebuild.html
As for a "screw" to lean it out - there isn't one. It's a feedback system, meaning it sets the mixture at a certain place, the O2 sensor sees what the result is, sends that info to the computer, the computer changes the mixture based on the sensor "feedback", etc., etc.
The typical causes of running too rich are: Bad O2 sensor (but not bad enough to set a trouble code); improperly functioning choke; leakage through the "well plugs" from the fuel bowl to the intake manifold; and ignition not up to par.
Old 07-13-2007, 09:31 AM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
I just purchased a boat with a 90 Q jet on it (90 260HP 350 CI Mercruiser). I know theres no computer or anything but its in need of a rebuild big time. Would the diagrams I see here be there same - some computer components?
Old 07-13-2007, 11:35 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Axle/Gears: 3.54 Dana 44
They'll be largely the same.
sleprock
Interior Parts Wanted
10-03-2015 11:01 PM
hartsmike
10-02-2015 07:11 AM
Derrick86
10-01-2015 05:12 AM
Aaronv808
Members Firebirds
09-30-2015 12:55 PM
3.8TransAM
09-27-2015 08:37 PM
Quick Reply: rebuilding a quadrajet
