turn signal switch
Old 06-28-2007, 12:05 AM
aceman1's Avatar
Car: 1989 camaro
Engine: 2.8
turn signal switch
does anyone know how to remove the stering wheel lock on a 89 camaro? i need to change the signal switch and can only get as far as taking the wheel off.
Old 06-28-2007, 05:54 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: turn signal switch
Welcome to TGO. You might consider a search; however, IIRC, the stalk is removed by twisting and pulling (the wiring is disconnected under the dash at the base of the steering column); the wheel doesn't need to be removed.
JamesC
Old 06-28-2007, 08:16 PM
aceman1's Avatar
Car: 1989 camaro
Engine: 2.8
no i mean the computer thing thats beyond the wheel
Old 06-28-2007, 08:26 PM
pizza_guy's Avatar
Car: 84 Z28 H.O. w/Megasquirt II
Engine: semi-stock L69
Transmission: T-5 non W/C
Axle/Gears: 3.73 open
The steering wheel lock, as in the plate with the notches all the way around that the plastic piece goes through to lock the wheel in place.
You'll need a "lock plate remover" tool to get past it. It compresses that plate down, and then there's a pain-in-the-*** snap ring than needs to be removed.
I'd snag a Haynes manual while your at the parts store getting your "remover". It'll save a lot of headaches, cause you can read ahead and have somewhat of an idea of what your up against.
What "computer thing"? That confuses me.
Old 06-29-2007, 05:53 AM
JamesC's Avatar
Me too.
JamesC
Old 06-29-2007, 12:53 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
the compressor tool is dirt cheap 15 bucks or less
i have two of them use them all the freaking time
most of the time i dont put the plate back on
unless its not my vehicle
vehicle theft is EXTREMELY rare out here in corn field no where
http://www.mytoolstore.com/otc/7927.html
http://www.hpcworld.com/Tools/t_swlpc2.htm
http://www.kalyx.com/store/prodpage5...005.0/file.htm
Old 06-30-2007, 10:05 AM
my82roc's Avatar
Car: 89 Iroc Convertible
I had to do this before on my 86 Iroc.The turn signal switch snapped when I hit the lever and when that happened every time I made a turn the horn would go off because a piece of metal that broke off was connecting the contacts.That was alot of fun.But anyway once you get the lock ring and plate removed there are a couple phillips screws that hold the actual turn signal (cam)switch in place.Remove them,Disconnect the harness connector by the lower part of the steering shaft and slide it out through the column.You will most likely have to drop the column to do that part.Installation is the exact opposite.Just make sure it works before you put the column back together.Took me about 30 minutes to do.
TWON_3rdGEN (08-12-2019)
Old 07-05-2007, 03:44 PM
aceman1's Avatar
Car: 1989 camaro
Engine: 2.8
ya sorry guys. i didnt know the name of the part.
the box calls it a "switch commutateur interruptateur"
Fronzizzle
03-18-2019 08:29 PM
LittleFranks
09-17-2015 12:22 PM
Fronzizzle
08-17-2015 02:52 PM
Tony Ferrarri
08-11-2015 07:59 PM
Fronzizzle
08-09-2015 01:15 PM
Quick Reply: turn signal switch
