Removing TPI intake
Car: 1992 Z28
Removing TPI intake
I have an oil leak from the back of my intake. I need to replace the intake gasket and need to know if I should tackle this on my own. I've never done this before but it doesn't seem like its a nightmare to do. I don't have $500 to take it to a shop but I do have time. Does anyone have any tips on how I should do this? It looks like I can get by without removing the valve covers, true? Removing the TPI doesn't look to difficult either. Any advice? Thanks.
1992 Z28 (305) TPI.
160' stat, Accel 8mm, Accel Cap & Rotor,
Flowmaster, high-flo cat.
1992 Z28 (305) TPI.
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
I just did my first intake swap tuesday and it was easy. Take off the TB and plenum. along with the runners. Mark the distributer and pull that label your injecorts and unclip those. Remove the 4 fuel rail bolts and disconnect the gas line at the front of the engine and pull the injecotrs out. Remove the coolent temp sensor to drain soem of the antifreeze in the manifold. Then take out the intake bolts and lift up. Some antifreeze will get into the engine, but dont worry. Clean the heads of the old gasket lay a 3/8 bead (more is better) of RTV in the front and rear of the block. Lay your gaskets into place and put new intake on. tighten bolts to 35LBS and your set.
Car: 89RSconvtZZ4TPI
Engine: ZZ4TPI
Transmission: 700R4 TRIPP TRANNY
Just remember, there are two bolts holding the runners on that come from the opposite side as the other runner bolts. One is back by the distributor, the other by the IAC under the TB. The back one can be a real pain in the *** . I other words don't force anything. If they runners or plenum feel really tight coming off, don't grab the hammer, take a second look and make sure you didn't miss a bolt.
Lay that RTV in pretty thick and drop the intake straight down on the block, don't slide it around. Now would be a good time to clean up the insides of the intake, runners and plenum! good luck.
Rob P
89RSconvtZZ4TPI
92Z28convt5spd
71Impala convt 402BB
BETTER DRIVING THRU SUPERIOR HORSEPOWER!
Rob P
89RSconvtZZ4TPI
92Z28convt5spd
you can leave the tb on the plenum if you do the tb bypass mod. might as well anyway. also while the plenum is off, port it , also relocate your mat sensor and put on an adjustable fuel pressure regulator. torque the bolts down like this -->
http://www.racer-x.f2s.com/proc/torkseq.htm#tpiseq
Car: 1992 Z28
what do i need to do for a tb bypass mod? also, i was considering getting the plenum ported while i have it off. is there really much performance gain doing this? how much do you think it would cost to have em ported? thanks again.
1992 Z28 (305) TPI.
1992 Z28 (305) TPI.
port the plenum yourself, all you need is a drill and a few 1$ bits (rasp and sanding stone). for the tb bypass get dayco part #...(be right back) cant find the # but this shows the "quick ugly"way to do it. https://www.thirdgen.org/newdesign/tech/index.shtml
[This message has been edited by ron rizzotti (edited November 02, 2000).]
Car: 1992 Z28
honestly, i'm kinda nervous porting the plenum myself but i think i can do it. will a dremel tool be good enogh? got any pics on what the plenum should look like after its ported?
1992 Z28 (305) TPI.
1992 Z28 (305) TPI.
yea, you can use a dremel,, its real easy to do ,,go here --> http://www.tribal-treasures.com/cars...-port/port.htm
Car: 1992 Z28
thanks ron for that link. i have confidence i can port it now. i thought it was more involved. and there's a lot of other good stuff at that link.
1992 Z28 (305) TPI.
1992 Z28 (305) TPI.
Car: 1992 Z28
one more question; when i reinstall the runners, is there a procedure to bleed them or do i need to? i appreciate your help.
1992 Z28 (305) TPI.
1992 Z28 (305) TPI.
bleed??? im not sure what you mean.. but when you put the runners back on it is simple.. just bolt them 15-20ft/lbs. start from the inside bolts and go out . good luck
Car: '91 Z28
Engine: L98 5.7L TPI
Axle/Gears: 323's
One other word of advice... When you pull your intake and old gaskets, the gaskets are probably the kind that have the little metal retainers integrated to hold the gasket in place during installation, so be careful of those and make sure you account for every one of those after you get your intake off. I had a couple of mine pop off during removal, and that's how I discovered those...
KAM
KAM
1992rs/ss
05-19-2020 07:02 PM
Sanjay
08-12-2015 03:41 PM
