Comp Cams Xtreme XFI 268 sound clip
Old 06-22-2007, 08:49 AM
battman's Avatar
Car: 87 GTA, 88 GTA, 92 TA, 72 RS SS
Engine: 350, 350, 305, 396
Transmission: T56, 700r4, 700r4, T56
Axle/Gears: 3.42, 3.23, 3.23, 3.73
http://videos.streetfire.net/video/2...5500a00cf4.htm
I got a new video camera and recorded this little clip of my 87 GTA idleing. I think it has a decent little lope to it, it definatly performs well.
Here are the specs:
355 block
Comp Cams Xtreme Xfi268 roller cam
World Sportman II heads
9:8:1 compression
Intake is HSR with 58mm throttlebody and 24# injectors
Hooker 2055 headers and hooker aero catback
LS racing chips tune
Old 06-22-2007, 10:16 AM
CG_1985_Z28's Avatar
Car: 1985 Z28 camaro
Engine: lq4
Transmission: th350
Re: Comp Cams Xtreme XFI 268 sound clip
that sounds amazing
Old 06-22-2007, 03:55 PM
D's89IROCZ's Avatar
Car: 1989 IROC-Z
Engine: 5.7L EFI LTR setup
Transmission: T-5 World Class
sounds good , i am sure there are others that say thanx for the sound clip . Alot of people like to hear these before buying
Old 06-23-2007, 01:24 PM
Burnout91's Avatar
Car: '91 Z28 L98 G92
Engine: Modded L98
Transmission: Modded 700R4
Axle/Gears: Modded 10-Bolt
Yes, that does sound very cool! I have that same cam...waiting on headers to install it; I want to install the AFR 195's, XFI268h13, 1.6 rockers and Dyno Don's headers at one shot.
Thanx for posting the sound clip.
Bill
Old 07-29-2007, 04:11 PM
MedVader's Avatar
Car: 90 Formula hardtop
Engine: 5.0 TPI
Why does that cam have more lope than a CC305?
It's a smaller cam with less overlap, right???
Old 07-29-2007, 07:04 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
I would say it depends on where the idle is set at.
Old 08-01-2007, 10:57 AM
YenkoST's Avatar
Car: '90 C1500
Engine: SBC MPFI
Transmission: 4L80e
Axle/Gears: 4.30
It has less .050 duration but almost the same .200 duration so, the XFI has the aggressive lobes that make it sound so mean. I have the 274 XFI in my 383 with 10.6:1 compression.
Old 08-24-2007, 02:14 PM
Burnout91's Avatar
Engine: Modded L98
What was the engine idle speed set at during that sound clip? By the way, how happy were you with the LSR Tune?
Bill
Old 08-24-2007, 02:34 PM
battman's Avatar
around 750, overall I was happy with it, it had some bucking around 2000 rpm cruising though.
Old 08-24-2007, 03:08 PM
HD4mula's Avatar
Nice! That sounds like a 3" exhaust. Below is my XFI-268 in a different car. I have AFR 180 heads in a 355 10:1 with roller rockers, 52mm, AS&M runners, Edelbrock base, ported plenum, shorty 1 1/2" headers and 2.5" exhaust.
304hp/366tq to the wheels.
http://www.youtube.com/watch?v=mZsO_jbx3ZY
TreDeClaw
Theoretical and Street Racing
06-22-2021 08:21 PM
sweet_87_iroc
09-25-2015 10:01 PM
LT1Formula
08-20-2015 09:36 PM
TreDeClaw
08-14-2015 06:58 PM
Quick Reply: Comp Cams Xtreme XFI 268 sound clip
