DFI and ECM Discuss all aspects of DFI (Digital Fuel Injection), ECMs (Electronic Control Module), scanners, and diagnostic equipment. Fine tune your Third Gen computer system for top performance.
Problem with LT1 O2 sensors
Old 06-20-2007, 11:57 PM
94-6spd's Avatar
Car: 83 Z-28
Engine: 406
Axle/Gears: 3.70
I just got my LT1 running and it fuel smokes badly. The scanner readings are Left bank 128 and the Right is 151. PCMforless told me that it has an exhaust leak causing the O2 sensor to send a lean condition to the computer. The computer then compensates and richens the mixture. I thought it was a bad sensor so I changed it out. Still the same readings. Even with them unplugged it still reads the same. How does the readings change with the sensors unplugged? I can't find a leak ahead of the O2 sensor but found a small one directly after it at the collector. What gives?
Old 06-21-2007, 10:12 AM
pizza_guy's Avatar
Car: 84 Z28 H.O. w/Megasquirt II
Engine: semi-stock L69
Transmission: T-5 non W/C
Axle/Gears: 3.73 open
Re: Problem with LT1 O2 sensors
Well, a small exhaust leak on one bank only will reduce the volumetric efficency of that bank. That'll get you lopsided like that.
Old 06-21-2007, 01:50 PM
94-6spd's Avatar
Car: 83 Z-28
Engine: 406
Axle/Gears: 3.70
Why does it read the same when the sensor is unplugged? Does the computer not recognize the sensor?
Old 06-22-2007, 12:37 PM
pizza_guy's Avatar
Not sure about the LT1 PCMs, but if a new sensor resulted in no change, then I'd start looking at your wiring or your PCM.
Old 07-13-2007, 12:33 AM
ttypecamaro's Avatar
Car: 09 Cobalt SS Sedan. 92 Z28 vert
Engine: 2.0T EFR6758; 5.0TT T3/T4 8psi
Transmission: F40; 700r4
Axle/Gears: 3.76 LSD; 3.23 posi
this might be a case of the famous split BLM problem. I corrected it on my brother's car by slowly adjusting the base idle screw on the throttle body and watching the BLMs untill they were equal. The split BLM is caused by valve overlap on larger cams due to the short runner intake design.
db057
01-10-2020 08:55 PM
gta892000
08-11-2019 11:16 AM
HoosierinWA
10-07-2015 10:15 AM
customblackbird
10-01-2015 04:30 PM
BWilcox
09-20-2015 12:19 PM
Quick Reply: Problem with LT1 O2 sensors
