Tune up on a 1992 Z28
Old 06-17-2007, 02:02 AM
vjw757's Avatar
Car: 92 RS
Transmission: AUTO
i know this may seem like a stupid question. but what do i need to do a yearly tune up? Ive always just took it to the shop but i want to start doing this stuff my self. i have a 92 Z28 tpi locate at the link below... the only think i know is do a oil change and oil filter... spark plugs an wires... is that it? im thinking that cant be it so what else?
https://www.thirdgen.org/forums/tech...ml#post3373609
Old 06-17-2007, 04:16 PM
el_muerte's Avatar
Car: '87 Z-28
Engine: LT1-topped 400
Re: Tune up on a 1992 Z28
-grease the chassis
-air filter
-clean and gap the plugs
-visual check of wires for burning, chafing, etc
-set timing
-run a fuel injector cleaner through
-visually check belts for cracks, wear, check tightness
-check tire pressure, check for cracks, unusual wear, bulges
-look for any fluid leaks
-check tightness/play in driveshaft (u-joints)
-check or change transmission oil, differential oil, brake fluid, power steering fluid
-check coolant level/condition
do a nice engine shampoo, wash and wax the car
i'm probably forgetting a few things...
Old 06-18-2007, 02:25 AM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
- Lube, oil, filter
- Air Filter (if needed)
- Spark Plugs (cap, rotor, wires if needed)
- Clean throttle body and IAC motor
- Change PCV valve and breather filter (if necessary)
- Inspect belt or belts for wear, drying, or cracking
- Check belt tensioner operation
- Check coolant condition/voltage/acidity/hoses
- Charge battery
- Check tire wear, tire pressure
- Check trans, rear end, engine for leaks
- Check brake rotors/drums and pads/shoes for wear level
- Check swaybar bushings and end links
Looks like a long list, but most of it is just looking at parts of the car.
Old 06-18-2007, 11:43 AM
vjw757's Avatar
Car: 92 RS
Transmission: AUTO
thanks guys.. it defently does look like a huge list lol
Old 06-18-2007, 07:36 PM
86NiteRider's Avatar
Location: Somewhere around the South Side of Chicago just crusin' in one of the Niteriders
Car: 92RS 25th Anniv./88 IROC Z28 Vert
Engine: 305 TBI w/Tpi Air / 305 TPI
Transmission: 700r4/700r4
Axle/Gears: Posi
I suggest since you are not around to have the wife get a shop to do the tune up. Make sure they set everything back to factory specs via the computer. You might even let the dealer do it.
As far as the shocks for the hood and hatch, those can be bought new from any parts story...about $40.00 for all four and you can pop those on as soon as you get back in about 5 minutes.
God speed home safely.
Vintageracer
01-10-2020 05:33 PM
1992CamaroGirl
12-25-2017 08:45 PM
diana227vegas
07-08-2016 12:27 AM
zayne0
08-24-2015 07:22 PM
Bryan F
08-18-2015 02:28 PM
Quick Reply: Tune up on a 1992 Z28
