tips on installing jegster torque arm?
Old 06-14-2007, 12:21 PM
MaNiAk86's Avatar
Car: 1983 trans am
Engine: Vortec 350 w/ a comp cam
Transmission: B&Mth350 2800holeshot
Axle/Gears: 10bolt 3.23's
i bought the jegster adjustable trans tunnel mount torque arm used from a member here on tgo. it did not come with instruction and i contacted jegs by they said they could only mail the non-adjustable directions to me in 2-3 weeks.
i want to install it next wednesday(only day off). i just dont no where to set the adjustment for initial mounting and drilling holes( 14 holes scares me)
Old 06-16-2007, 04:53 PM
MaNiAk86's Avatar
Car: 1983 trans am
Re: tips on installing jegster torque arm?
i know of at least one person running it. im sure there is more than one. nobody has any tips? am i supposed to reuse the old hardware that bolts to the pumpkin? because im sure im gonna have to torch it off and i dont no what size bolts i need.
Old 07-23-2007, 07:32 PM
formulazz4ws6's Avatar
i installed one on my 89 formula and it was a royal pain. you need to re use the pumpkin hardware. for me the hardest part was drilling the 20 or so holes in the car to install it
Old 07-23-2007, 10:29 PM
drex's Avatar
Car: 87 formula and 85 olds delta 88 2 d
Engine: 60's 350 holley carb and intake
Transmission: muncie 4 speed with centerforce
Axle/Gears: 3.42 99 camaro rear w/ discs
i installed the jegster non adjustable arm... it was easy drop the driveshaft... put it up in there ... have all the weight on the tires so you see true ride height....bolt the arm to the pumpkin and slide the joint in and bolt the pin up... leave the pin out about an inch or so for movement and put the grease fitting down..then drill the 4 outside ones and bolt it up and then the rest... remove carpet makes it easier..will be right over the e- brake cables..feels solid
Old 07-24-2007, 01:26 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
FWIW - The TA bolts going into the diff are M14 bolts, 180mm long. I think you can use 9/16" bolts that are 6" long IIRC. That's what Spohn sells as a replacement part.
Old 07-25-2007, 02:50 AM
F-Body Demon's Avatar
Not sure if it will help but I did a Edelbrock adjustable arm and it all worked better after I dropped the tranny a little. I just but the jack under the tail, loosened the crossmember bolts a bit and let her down an inch.
Helped ALOT!
Old 07-25-2007, 10:14 AM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
i believe you can download the instruction from jegs.com, if not it's fairly straightforward of an install. Leave a 3/4" gap at the end with the suspension loaded and the grease fitting pointing down and that about covers it. Adjusting pinion angle isn't difficult either, took me under 2 hours from start to finish.
Old 08-03-2007, 02:56 PM
Night rider327's Avatar
Car: 1988 Camaro
I installed the adjustable jegster arm on mine.. Here's you some pics to go by.
http://rides.webshots.com/photo/2192...41290424mkdfQU
http://rides.webshots.com/photo/2770...41290424SJlSHO
http://rides.webshots.com/photo/2147...41290424hKjluE
http://rides.webshots.com/photo/2828...41290424mazMgQ (look close and you can see the bolt heads on this side, down the trans tunnel)
http://rides.webshots.com/photo/2356...41290424KXjfSy
Old 08-03-2007, 06:40 PM
Demon355's Avatar
Will this work with a 9 bolt? I think this would be easier with my Super T10 swap.
Old 08-03-2007, 10:15 PM
xpndbl3's Avatar
Car: 1984 Z28
yes it would work on a 9 bolt
Nervous2
LSX and LTX Parts
03-10-2016 09:49 PM
sweet_87_iroc
09-25-2015 10:01 PM
Thirdgen89GTA
08-20-2015 03:11 PM
Dialed_In
08-20-2015 01:45 PM
Quick Reply: tips on installing jegster torque arm?
