Royal purple and flat tappet cams?
Old 06-08-2007, 09:36 PM
Freakazooid52's Avatar
Car: 1986 firebird
Transmission: THM350
I have a older 350 in my firebird, and it has a flat tappet cam, I need oil with more ZDDP additive then todays regular 10w-30 which has about 600 when I need 1000 or more. dont need my cam wiping, lol.
The valvoline Vr1 oil has 1200 PPM per quart which is what I need but I have to order it, Ive heard good stuff about royal purple and I can buy it around me
Anyone know the Zinc content in their 10w-30 grade?
Old 06-08-2007, 10:06 PM
GuitarJunki17's Avatar
Car: 1990 IROCZ Camaro
Engine: 350 4bbl, 200cc Heads, 270hr Cam
Transmission: 700R4 w/ Trans-Go shift kit.
Axle/Gears: GM 10 bolt Posi
Re: Royal purple and flat tappet cams?
A buddy of mine just got done breaking in a motor with Shell Rotella T Diesel oil. Diesel oil has a higher amount of zinc in it and is good for breaking in cams. Royal purple is too expensive in my opinion to be used as a break in oil, seeing as you will be changing it out shortly anyhow.
Old 06-08-2007, 10:10 PM
Rayzor32's Avatar
Car: '89 IROC-Z
Transmission: 700r4 edge 3000 stall
Axle/Gears: 9-bolt 3.73
go with castrol HEAVY DUTY for break ins
Old 06-09-2007, 12:45 PM
Car: 1986 firebird
my engine is aleready broken in, it gots a little over 8000 miles aleready. Sorry for not saying it earlier.
But does anyone know if RP regular 10w-30 oils have good anti wear for flat tappet cams?
Hotrodboba400
12-10-2019 07:07 PM
nugentcj
Camaros Wanted
12-22-2015 02:58 PM
Jorlain
10-08-2015 01:57 AM
Ironhead38
09-07-2015 02:26 PM
Hotrodboba400
09-02-2015 07:28 PM
Quick Reply: Royal purple and flat tappet cams?
