how to fix a code 53?
Old 11-18-2001, 03:05 PM
91rsrider's Avatar
ok i got a code 53,and now my car isnt starting.i turn the key and get nothing at all from the starter.i read that a 53 is overvoltage?exactly what causes that,and how is it fixed.thanks guys.
~*Formerly known as 91rscruiser*~
-1991 camaro rs,dark red metallic,t-tops,stock 15inch rims,Z28 bowtie grille insert with driving lights
-L03 305,TH700R4,2.73's,only mods for now are...Flowmaster 80 series replacement muffler,accel wires and coil,14x3 open element with K&N,lockup switch at the track,and a catco cat.
-best 1/4 mile times to date:15.89@86 with a 2.26 60 ft
Old 11-18-2001, 03:28 PM
JPrevost's Avatar
Car: 91 Red Sled
Bad alternator, bad alternator connection, bad ecm. Those are the most common causes. That code only comes on when the engine rpm is over 800rpm though. Double check your ecm connection. Try and turn the car over with the alternator unplugged! Watch the voltage at the battery very closely! Then when you've tried all that come back and make a post and I'll post the way to check the voltage at the ecm.
Old 11-18-2001, 04:04 PM
91rsrider's Avatar
ok well i went back up to work where the car was dead with the spare key that i so luckily have and it started thanks *** .my buddy suggested that i use the other key after i searched the boards for code 53 and saw that some people mentioned it could be the vats system at large in a few of those code 53 posts.and then when i got home,i used the key that wouldnt work for $hits and giggles,and it worked.i dont know whats going on.i dont really care though as long as my car works.i think im going to bypass the VATS so i dont have to worry about it screwing me over again.thanks for the post anyways JPrevost.
GeneralIesrussi
Carburetors
01-20-2020 01:06 PM
gta892000
08-11-2019 11:16 AM
BumpaD82
02-26-2016 02:57 PM
64Chief
09-12-2015 08:05 AM
Quick Reply: how to fix a code 53?
