ls1 t56 vs. lt1 t56
Car: 1992 camaro Z28
Engine: 305 tpi
Axle/Gears: 3.42 4th gen posi
ls1 t56 vs. lt1 t56
is there a difference? I want to bolt a 2002 t56 of off a ls1 up to my tpi motor, I have looked through the tranny forums and have not found anything addressing this? thanks
Car: Pair of 92 Z28s
Re: ls1 t56 vs. lt1 t56
LS1 T56s use a completely different bellhousing bolt pattern as well as several other differences. It can be done but not without a lot of work and modifications. 93-97 LT1 T56s bolt right up.
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
If you have an LS1 T56 set-up sell it and buy an LT1 T56 set-up. The going market rate is roughly the same for the two and it is far easier to sell one and buy the other. You can convert as mentioned above but it is not worth it when you can basically exchange the unit you have for the the one you need without any further damage to your wallet.
Car: 1999 Camaro Z28
Engine: 5.7
You could catch some good money for the LS1 T56 over at LS1Tech.com if you already have it. The input shaft on the Tremec (LS1) T56 is a different length, also the clutch setup is different and flywheel. If your not using an LS1 your better off going LT1 (borg-warner version) or aftermarket. Also the Tremec version is rated for less torque than the BW version if I recall correctly
