Large cap HEI for TBI engine
Old 04-03-2007, 10:41 AM
onebad89RS's Avatar
Car: 89 RS
Engine: 305 carbed
Axle/Gears: 3.42 auburn posi
Well i have discovered a way to use a performance ignition with my stock TBI. and what a diffrence it made! if anyone is intersted in how i accomplished this let me know i can send my wiring digram of how i trick the PCM into thinking there is a stock distributor there. my engine revs so much quicker, and because of the advance curve feels like it has more power at low rpms.
The following 3 users liked this post by onebad89RS:
Bubba Moon (11-20-2019), Chevyk1500ris (04-22-2022), ravenwooddrb (12-29-2023)
Old 04-03-2007, 10:48 AM
Fast355's Avatar
Car: 1983 G20 Chevy
Re: Large cap HEI for TBI engine
Not suprising at all, but it can be done cheaper by investing in a Prom Burner.
I have seen alot of TBI conversions run by the tach signal.
PS- I am not knocking your work at all, just giving an alternative for everyone else.
My Oldsmobile 307 TBI conversion runs on a CCC Q-Jet large cap HEI.
Old 04-03-2007, 11:00 AM
onebad89RS's Avatar
Car: 89 RS
Engine: 305 carbed
I know it may not seem like a big deal, but with lack of performance distributors for CC tbi cars. and with the numerous non-cc distributors being made for carbed cars. i figured this was an easy way to gain performance, and tunability without a laptop. not to mention i can hook up an ignition box such as MSD alot easier with this setup. it was quite a challenge to get this to work the right way. mainly because the way it's wired
Old 04-03-2007, 11:09 AM
ryan77's Avatar
Car: 89 Camaro, 00Xtreme s-10, 89 Buick "Party Ave"
Engine: 305tbi
Transmission: 700r
sounds good...I have an extra hei dist. laying around that had a curve kit...yea, send me the diagram....thanx
Bubba Moon (01-11-2020)
Old 04-04-2007, 01:48 PM
ryan77's Avatar
Engine: 305tbi
Transmission: 700r
does this also work on tpi 350's???
Mortorq (04-24-2021)
Old 04-04-2007, 03:53 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Any system that originally had the CC HEI.
Id love to convert over. the stock ignition system has always been an issue due to the lack of decent replacement parts. The only thing is that Id no longer have the flexibility of using the computer to control the timing. With the computer, setting the timing curve for the idle and open throttle is basically nothing more then banging on a keyboard for a few minutes. This and theres also alot more functionality for startup, idle speed control, and for preventing detonation.
Does anyone make any reasonably priced afterkmarkets that can be controlled by the computer?
Old 04-05-2007, 07:55 AM
Damon's Avatar
The earlier HEIs work by the exact same basic principles as the later computer controlled ones. You won't find that a non-computer controlled HEI has any more juice than a computer controlled one. However, lacking a way of programming a computer controlled one it would certainly be a way of getting timing adjustment back to basic mechanical systems- springs, weights, vacuum advance. Given that the STOCK ignition curve on a TBI engine is rather weak and leaves a lot of performance on the table, I can imagine that going back to a early HEI and dialing in the timing curve could probably make the engine quite a bit stronger. Like was mentioned above, however, nothing that couldn't be done just as well or better by programming the computer controlled HEI's timing curve better than the stock programming.
Old 04-05-2007, 08:15 AM
Car: 88 Camaro SC
Engine: SFI'd 350
My beef with the stock system is that there is no support. The only parts available are junk and constantly go dead. It sucks because its easier to tune and more flexible then using a non-CC HEI dist.
Old 04-05-2007, 09:26 AM
onebad89RS's Avatar
Car: 89 RS
Engine: 305 carbed
Ryan the mechanical HEI is rather large and would probably not fit behind the manifold. and so far i've tuned my hei for my car. and i can definatly tell you it woke my car up grately. i notice the most gain under 4000rpm. mainly cuz of the way the advance comes in kinda agressivly and where i want it. my car wouldn't spin the tires off the line more then 5 feet in the past. now it has the torque to spin them throughout 1st gear. The main reason i went mechanical is manily cuz i'm not a big fan of electronic stuff. but thats my own opinion.
Old 04-05-2007, 02:39 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Dimented, have you tried GM stuff for the ignition module & shaft? I've found that the GM stuff does the job. I'll even buy a distributor from the junkyard if it has a GM ignition module. The other GM important part is the shaft with the 'star wheel' on it. The pickup coils I've gotten at places like NAPA & Car Quest.
RBob.
Old 04-05-2007, 03:03 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Axle/Gears: 3.54 Dana 44
Maybe not so easily. The automatic dwell circuitry in the 4 pin module doesn't like talking to an MSD box.
Old 04-05-2007, 03:27 PM
Damon's Avatar
When you convert a non-computer controlled large cap HEI over to an MSD box you bypass/remove the module completely. Wired striaght into the mag pickup. Very different install than with computer control.
Old 04-05-2007, 03:31 PM
Apeiron's Avatar
Engine: 383 Carb
Right, so it might be difficult to use the large-cap mechanical advance distributor with an MSD box and still be able to fool the ECM.
Old 04-05-2007, 06:55 PM
Damon's Avatar
Don't know. If he can trick the ECM into thinking the original distributor is still there, as he claims, then the ECM wouldn't know you put an MSD box on the actual distributor that's running the motor. Once the ECM is "blind" to the actual distributor that's running the motor it really wouldn't matter whether you added an MSD to it or not.
I'd like to know how he did it. Maybe he'll post it up for all to see.
Old 04-05-2007, 09:10 PM
onebad89RS's Avatar
Car: 89 RS
Engine: 305 carbed
I've been having trouble getting my scanner to work but if i can figure out how to post a picture of my wiring diagram i'll take a picture of it and upload it...anyone know how?
Old 04-05-2007, 10:08 PM
onebad89RS's Avatar
Car: 89 RS
Engine: 305 carbed
ok i have an attachment of my wiring diagram i made in paint. it's kinda distorted but it should still work.
Old 04-06-2007, 09:45 PM
va454ss's Avatar
Car: 90 454SS
Engine: 454 TBI
Transmission: TH400
I'm using the Performance Distributors CC big cap HEI.
Can't remember the wiring changeover as I did this several years ago.
Old 10-01-2010, 08:54 PM
pillsbury_dboy's Avatar
so i attemped this got it it runs amazing but im having one issue, the fuel pump wont prime and starts up like its fully carburetor in the winter! i was curious if anyone else who has did this doing the same? does this to after switching the distributor or if one of my wires r connections r just poor. i also have the base timing set at 4 degrees advanced which is stock because im trying to pass emissions.
Old 10-02-2010, 01:59 AM
UnderCover89TBI's Avatar
Engine: gone
Transmission: gone
Axle/Gears: gone
D.U.I makes a computer controlled HEI distrubutor for the TPI cars. Im sure it'll fit in tbi cars. Is that what some of yall are needed? Summit sells them. If that's not what you meant sorry for wasting a post spot.
Old 11-10-2010, 01:12 PM
SB406's Avatar
Car: 71
Engine: 406
Axle/Gears: 3.42 8.5" 10b
Bumping an OLD thread. The above quote has me curious.
Say I have an old school SBC with an HEI vacuum advance, coil in cap dizzy. Electronic ignition, not points. OK, now I want to put a TBI (1227747) setup on it to control fuel only, and leave the HEI alone.
Can I do this without running a 2nd ICM as discussed above? ECM needs to know RPM to run the injectors. Like, can I just run a signal off the tach wire to a pin on the ECM? Or does it need some conditioning? ECM has 4 pins: EST, Reference, bypass, Reflow. Can I just hook pin D4 (EST) to the tach side of the coil?
I know Howell makes a TBI unit (For Fords, Jeeps, etc) that does only fuel, uses a 1227747 ECM, and uses 1 wire to the ECM for tach signal. I'm trying to figure out how they do it, so I can do the same with a factory harness.
Old 12-26-2010, 03:16 PM
father of 6boys's Avatar
will it effect emmisions
Old 03-10-2016, 07:40 PM
Kyle1987's Avatar
Hey could you send me the diagram?
Old 03-10-2016, 08:50 PM
RamIt's Avatar
Car: 1984 z28
Engine: 93 LT1 350
Axle/Gears: 7.625" 28 spline 3.23
Did you read the thread?
Look 6 posts above yours.
Old 03-10-2016, 09:09 PM
Ron U.S.M.C.'s Avatar
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
Kyle1987,
Welcome to Third Gen.Org.
Help us help you.
Simply go to USER CP
then
EDIT YOUR DETAILS
then fill in the last 4 lines at the bottom of the page.
Car =
Engine =
Transmission =
Axle/Gears =
If you don't know just put "unknown"
Old 03-11-2016, 11:33 AM
Schurkey's Avatar
Interesting thread. I'm not used to seeing that much questionable or outright wrong information in one place, unless it involves air intake via open-element or "warm-air induction".
Old 11-20-2019, 04:44 PM
Bubba Moon's Avatar
please send me info
Old 11-22-2019, 06:55 PM
Buccaneer's Avatar
Car: 82 Corvette - CFI
Engine: 383 - Renegade, AFR 195, Bullet cam
Transmission: 700R4 - 3,200 Yank TC
Axle/Gears: 3.31
I know this is a really old thread, but maybe a little bit better pic to read for someone.
Old 11-22-2019, 09:53 PM
Schurkey's Avatar
I don't understand this. The large-cap HEI module typically has four "blade" connections (plus the "hidden" ground connection to the distributor via one of the module hold-down screws.)
Two for the pickup coil, labeled W and G on the module, connected to White and Green wires from the pickup coil.
Module B+ which is also ignition coil B+ or "BATtery".
Module C- which is also ignition coil C-, or the TACH terminal on the side of the cap. (you get a spark from the coil when the module opens the C- circuit.)
Your diagram is missing the + and - wires to the ignition coil. In your diagram, the C- from the "New HEI Distributor Control Module" is connected to the PCM. I don't think this is correct. It should connect to the coil C- (TACH) terminal. There should be another splice in the B+ circuit, going to ignition coil B+ (BAT). Now the "new HEI" module controls the coil.
The whole point of running two modules is so that the OEM, computer-controlled system can "dry-fire"; it works as normal but it's not connected to an ignition coil. It's just along for the ride, so that the computer thinks it's functional. While the computer-controlled module ***********, the 4-pin HEI module actually controls the coil, so that the centrifugal and vacuum advance affect spark timing instead of the computer--which is too stupid to know what's really going on.
This is really clever. I'd have never thought of it independently; although I did read about it on another forum. The only questionable part is whether the pickup coil can provide enough power to activate two loads instead of just one; and apparently it can--but I bet at low cranking rpm (cold weather, thick oil, low battery voltage) all bets are off.
Old 11-22-2019, 10:02 PM
Buccaneer's Avatar
Axle/Gears: 3.31
Your diagram is missing the + and - wires to the ignition coil. In your diagram, the C- is connected to the PCM.
Take a look at post #16. It's the same thing, just made it easier to understand. If it's wrong and I didn't verify it, then the OP was wrong. Sorry.
Old 11-22-2019, 10:38 PM
Schurkey's Avatar
I think the author of #16 has the original error. This is what I had in mind. Thoughts?
Old 11-22-2019, 11:02 PM
Schurkey's Avatar
Never mind.
Old 01-11-2020, 07:41 PM
Bubba Moon's Avatar
please send me info
Old 03-25-2020, 05:54 PM
Jeep V8's Avatar
please send me wiring diagram!!!! Thx!
Old 03-25-2020, 06:03 PM
Tuned Performance's Avatar
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Good luck getting information from someone who has 2 posts.
Old 03-25-2020, 10:07 PM
Schurkey's Avatar
Do you not see the diagram, posted right here on this thread?
No promises on it working. The whole thing sounds suspicious to me.
Old 08-06-2020, 07:34 PM
Brandon1980's Avatar
I would like to see wire diagram doing the swap on my 95 chevy
Old 08-07-2020, 11:31 AM
Schurkey's Avatar
Old 08-07-2020, 01:29 PM
GeneralDisorder's Avatar
REALLY stupid idea.
GD
Old 08-07-2020, 09:05 PM
Mperez's Avatar
I have a 1992 silverado with TBI Im trying to use a HEI distribuitor, can yoh send me the wire harness diagram please.
Thank you
Old 08-07-2020, 09:24 PM
Engine: Lb9
Transmission: M20
92 tbi uses hei divorced coil. If you wanting to go coil in cap just match the icm colors
Old 08-07-2020, 11:37 PM
What the hell is with all the idiots asking for a diagram that's posted in this thread? READ you morons!
STILL an exceptionally stupid idea.
GD
The following 3 users liked this post by GeneralDisorder:
Schurkey (12-28-2021), scooter (11-29-2020), trlrider (05-13-2021)
Old 08-08-2020, 02:55 AM
Fast355's Avatar
Car: 1983 G20 Chevy
GD
Large cap HEI is not an exceptionally stupid idea. Trying to adapt one that is not for an EST computer application is however exceptionally stupid.
Old 08-08-2020, 03:07 AM
That's clearly what they are asking to do. Adapt a vacuum/centrifugal non-ESC distributor. I doubt they even know that large cap ESC distributors exist.
GD
Old 08-08-2020, 03:58 AM
Schurkey's Avatar
GD
Wouldn't matter. The point is to get the ignition advance controlled via a mechanism they can "tune", instead of having to re-program a computer, which they can't. (No offense, I can't reprogram either.)
So to get "achievable" advance tuning, but NOT activate the "check engine" light, they use both modules, one to actually create sparks, and one to hand-job the computer to keep it happy.
Inelegant...but it would accomplish the goal.
Old 08-09-2020, 09:09 AM
Bill Chase's Avatar
Are people still this computer illiterate? i mean hell at a minimum get an msd box that is completely programmable based on map, tps, and rpm. especially for a street car.
Old 11-28-2020, 10:09 PM
Steven Windle's Avatar
Can you Send me the diagram please i really want to do this thank you
Old 11-29-2020, 02:58 AM
Schurkey's Avatar
GD
Engage brain before posting.
Old 11-21-2021, 10:43 PM
Boflex79's Avatar
How did you do that can you send me a wire diagram of how I can run HEI distributer to my TBI carburetor... please and thank you!!!
Old 11-22-2021, 12:34 AM
Schurkey's Avatar
Look two posts above this one.
Old 02-17-2022, 02:24 AM
Vázquez trek's Avatar
[QUOTE=Schurkey;6340832]No entiendo esto. El módulo HEI de gran capacidad generalmente tiene cuatro conexiones de "cuchilla" (más la conexión a tierra "oculta" al distribuidor a través de uno de los tornillos de sujeción del módulo).
Dos para la bobina captadora, etiquetadas como W y G en el módulo, conectadas a los cables blanco y verde de la bobina captadora.
Módulo B+ que también es bobina de encendido B+ o "BATtery".
Módulo C- que también es bobina de encendido C-, o el terminal TACH en el costado de la tapa. (Obtiene una chispa de la bobina cuando el módulo abre el circuito C).
A su diagrama le faltan los cables + y - a la bobina de encendido. En su diagrama, el C- del "Nuevo módulo de control del distribuidor HEI" está conectado al PCM. No creo que esto sea correcto. Debe conectarse al terminal C- (TACH) de la bobina. Debería haber otro empalme en el circuito B+, yendo a la bobina de encendido B+ (BAT). Ahora el módulo "nuevo HEI" controla la bobina.
El objetivo de ejecutar dos módulos es que el sistema OEM controlado por computadora pueda "disparar en seco"; funciona normalmente pero no está conectado a una bobina de encendido. Es solo para el viaje, por lo que la computadora piensa que es funcional. Mientras que el módulo controlado por computadora se masturba, el módulo HEI de 4 pines en realidad controla la bobina, de modo que el avance centrífugo y de vacío afecta el tiempo de chispa en lugar de la computadora, lo cual es demasiado estúpido para saber lo que realmente está pasando.
Esto es realmente inteligente. Nunca lo habría pensado de forma independiente; aunque lo leí en otro foro. La única parte cuestionable es si la bobina captadora puede proporcionar suficiente energía para activar dos cargas en lugar de solo una; y aparentemente puede, pero apuesto a que a bajas revoluciones de arranque (clima frío, aceite espeso, bajo voltaje de la batería) todas las apuestas están descartadas.[/CITA
]hello I have the same problem
i removed an electronic distributor and installed an HEI distributor these are my steps
1 cut the pink or red wire and put it in the battery.
2 place the tachometer wire in tach.
the question is if I am missing one more step
Quick Reply: Large cap HEI for TBI engine
