What are signs of a bad Timing chain?
Old 07-26-2001, 01:12 AM
ZRATED's Avatar
The last time I went to the track I came back very disapionted becuase all i could get out of my RS was a 15.9 thats down from a 15.3. I then went to the shop close by becuase I had a rough idle and the oil presure kept bouncing up and down and they said it could be the timming chain. I also get no trouble codes and most of the sensors are close to new.
One Tight Teal green 91 RS (my first car
All Rustangs suck!!!!
5.0 TBI with Auto trans
Z-28 wheels
K&n with dual snorkel intake
Rapid Fire plugs with Accel ignition wires,coil,cap and rotor
Flowtech headers with flowmaster and Half way cutout
B&M shift kit with trans cooler and hurst hotshift fulid
Hypertech thermomaster chip
All the free TBI mods
Old 07-26-2001, 05:50 AM
Pukka's Avatar
Location: Where the chicks absolutely LOVE the V-8 rumble!
Car: 92 RS - Fully Restored w/Custom Int
Engine: LO3 with some mods
Axle/Gears: 3.42 Richmond
I could be wrong, but I've never heard of "signs" of a bad timing chain. They are either bad or good...and when they go bad you know it pretty quick.
If you don't know for sure if the car ever had a new one put in and it has over 100k on the clock, then you should consider getting it done
92 Camaro RS, LO3, 5-spd, T-tops
Performance:
K&N Open Air Filter, Edelbrock performer TBI intake, Fastchip Prom, Timing +4 degrees, Centerforce clutch, Xact 8mm wires, SLP 1 3/4" Headers (coated), Flowmaster Catback Exhaust, Z28 Grille w/aftmkt fog lamps, MacEwen white-face guages
Electronics:
Alpine 8030 Alarm System, Valentine One Radar Detector (How did I ever drive without one?), Pioneer DEH 7450 Head Unit w/6-pack CD changer, Pioneer DEQ 7600 Sound Processor, 2 Kenwood KAC-846 Amps powering 2 12" Pro Red subs, 2 Pioneer 6x9 and 2 MTX 4x6 speakers.
NEXT UP: TBI mods, 3.42 gears w/Torsen posi
Old 07-26-2001, 09:59 AM
Spyder's Avatar
A problem that my father was having on his big block Chevelle (twice now) when his timing chain streched out, for some odd reason it would skip a gear throwing the timing off (20 or 35 degree's I can't remember) Then finally one day it just wouldn't start. I know this was a random story but it just might be the problem.
Old 07-27-2001, 09:42 PM
ChevelleCLM's Avatar
If you "jumped a tooth" on your timng gear, it would run bad, but usually, they either work, or they do not work. Pull the front off the motor, and replace it. It can be done for under 100 dollars, and in about 3 hours.
Hell, if you have the timing chain cover off you might as well pull the intake, and stab in a better cam.
69 Chevelle 2dr hardtop blue, bench seats, 12 bolt w/3.73's muncie 4 speed. best 14.5@90
Old 07-27-2001, 09:51 PM
DartByU's Avatar
Car: 92 Camaro RS
If the chain is worn badly sometimes you can hear it slapping around, if you have over 100,000 miles I would say go ahead and change it. I have seen them get so loose that the chain slapped the timing cover and wore a hole in it causing a big oil leak.
92 Camaro RS 5.0 5-Speed (Quasar Blue)
T-Tops
14" Open Air Cleaner
3.08 Posi-trac
Edelbrock TBI Intake
Crane cam
Ported & polished stock heads 3 angle valve job
HyperTech Chip
SLP Headers (Ceramic Coated)
UltraFlo cat-back exhaust
74 Dodge Dart Sport 360 (11.2 1/4 mile)
2000 Dodge 1500 Ram Sport
Old 07-28-2001, 11:36 AM
CHVYPWR's Avatar
Car: 1978 El Camino SS
Transmission: T-5 & 3.73's
Somtimes a timing light will help to show a worn chain. If your timing mark jumps around while the light is on it, the chain is loose. If your car has over 70,000, you can bet on your chain being sloppy.
Ya can't have too many fast Chevys!
Old 07-29-2001, 02:56 AM
ZRATED's Avatar
Thanx for the insight guys!!!
I will take a closer look at it
Z-28 wheels
Old 07-29-2001, 09:33 AM
Vader's Avatar
Top Ten signs of a bad timing chain:
#10 - It comes in an engine that has the word "Hyundai" cast in it somewhere;
#9 - You shut off the engine on Saturday and the distributor finally gets around to stopping on Monday afternoon;
#8 - Your timing chain has been stretched out more than Madonna;
#7 - When you're not looking, it crawls off the sprockets and takes twenty minute breaks in the oil pan;
#6 - You wake up in the morning and find your timing chain sleeping with your wife;
#5 - Your ignition and valve timing reminds you of a kid with a Honda V-Tec that thinks his car is fast - really, really retarded;
#4 - Your chain has been off on an Extacy binge for six days straight;
#3 - The hookers in Times Square tell you "We would, but we don't want to get caught with someone with a timing chain like yours." ;
#2 - Your timing chain has appeared twice on "America's Most Wanted";
The number 1 reason your timing chain is bad - it was made by Fram.
Later,
Vader
"Let the bodies hit the floor!"
Adobe Acrobat Reader
Vintageracer
01-10-2020 05:33 PM
Infested
05-22-2018 11:56 PM
ziggy89
Exterior Parts Wanted
09-10-2015 08:44 AM
MY87LT
08-17-2015 08:43 AM
Quick Reply: What are signs of a bad Timing chain?
