Smog pump delete info needed
Old 03-06-2007, 07:18 PM
Gallileo60's Avatar
Car: 89 RS, 92 Z28
Engine: 305 TBI, 350 TPI
Transmission: 700R4 Both Cars
Axle/Gears: 3.23 Posi.. 4 wheel disc both cars
I have a 1989 L03 TBI car with the power steering, and altenator on the drivers side the AC, and smog pump on the passenger side...I want to dump the smog pump, and not use a delete pulley (If that is possible) I have seen a couple of pics of belt routing, but have not seen one like my setup...Will someone PLEASE post a pic, or drawing of the correct way to route the belt to eliminate the smog pump....I looked at it for an hour today, and could not for the life of me figure it out.....If there is a sticky, or tech article on this I have not seen the one for my setup.....I did see the TPI one, but mine is not like that....Thanks for any help on this issue........Tom
Old 03-06-2007, 07:46 PM
Dewey316's Avatar
Car: 1990 Camaro RS
it is pretty easy, I dont' have a good pic.
From the AC, the belt goes down and below the crank pully (ribs line up), it goes almost all the way around the crank pully, then over the top of the water pump (flat side meets water pump, over the water pump, and down and around the PS pump, then up to the alternator, and over.
I don't know if that describes it all, it was the best I could do without a pic. Also, your stock belt won't work, you will need to get a bet that is a hair longer. IIRC i used like a 96.5" or 94.5" belt. It has been a long time since I had serp belts though.
Old 03-06-2007, 08:45 PM
Gallileo60's Avatar
Car: 89 RS, 92 Z28
Dewey, thank you very much..I will print this, and read it while I look at the car.....How long have you been runnig like this?????????? Any problems at all????Meanwhile anyone got a pic?????
Old 03-06-2007, 09:59 PM
Supporter/Moderator
ShiftyCapone's Avatar
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
This should help. Do a search in the FAQ board for "this is what your AIR system looks like". I have a pretty detailed thread in there that I posted years back.
Lets try this again.
It looks like I can't attach duplicate images even if I rename them. Refer to this thread for the image.
https://www.thirdgen.org/forums/exha...pump-help.html
Last edited by ShiftyCapone; 03-06-2007 at 10:02 PM. Reason: Automerged Doublepost
Old 03-07-2007, 06:53 AM
Gallileo60's Avatar
Car: 89 RS, 92 Z28
Thanks alot Shifty...you are my hero........LOL.....
Old 03-07-2007, 11:57 AM
Dewey316's Avatar
Car: 1990 Camaro RS
It runs fine, I ran like that for a couple of years. I have now converted to v-belts with only a PS pump and alternator.
Old 03-08-2007, 03:44 PM
l_dis_travlr's Avatar
Car: 90 Formula -- tot resto in progress
Transmission: 700R4 w/ 2500 stall, by Owen @ ARD
Axle/Gears: 3.23 posi disc
Check the Miscellaneous Mods section in the Tech Articles Tab.
It even identifies the different belt needed.
I heard how hard it was to wrap the headers. But come-on..
Cut off the air tubes & get a welder to close them up.
(Blasting & re-coating would be really spiffy!!!)
That's the least you can do for saving you the big
aw-s*** on that manifold swap
Old 03-08-2007, 06:26 PM
Gallileo60's Avatar
Car: 89 RS, 92 Z28
Yeah, I might do that...Good idea....I might get those headers on one day...lol...Looks like alot of work....It seems like my whole life is spent under the hood of my car.....Am going to pull the smog pump off Sunday..(I hope) right after the sway bar swap..And man are you right on the Aw **** on the manifold...I never noticed that and ive had the car quite awhile......Thanks for the input.Tom
Old 04-19-2007, 10:23 PM
johnnyboy's Avatar
Car: '82 formula clone, 95 saab 900se
Engine: 350 vortec'd tbi, 2.0L turbo
Transmission: 700r4, 5 spd
Axle/Gears: 10 bolt 2.77 open
Re: Smog pump delete info needed
how is it that you need a longer belt with one less pulley?
Old 04-20-2007, 09:51 AM
xjcamaro89's Avatar
Car: 1989 Camaro RS
Engine: 350 Holley TBI Personally Tuned
Transmission: 5 Speed
If you could you might want to just put a delete pulley on they arent that much and bolt on really easy, you dont want to throw a belt, thats a long way for the belt to travel from the crank to the AC unit. Just a thought, but if your going down the road and you loose power steering and amps, then you probably threw a belt.
Old 04-20-2007, 10:05 AM
91 camaro racer's Avatar
Car: 91camaro rs,2014 silverado 5.3L
Engine: 5.7Lcarb,5.3L
Transmission: 700-r4, 6L80
Axle/Gears: strange 3.73's
i have been driving with no ac or delete pulley for over a year now, no problems what so ever
Old 04-20-2007, 10:32 AM
xjcamaro89's Avatar
Car: 1989 Camaro RS
AC is different, there isnt as much distance from the smog pump to the water pump, as there is from the crank to the AC if you just take the smog out. Im not saying it will happen, but its a possibility.
Old 04-20-2007, 10:34 AM
i didn't mean to say ac, i meant smog pump my bad
Old 04-20-2007, 10:39 AM
xjcamaro89's Avatar
Car: 1989 Camaro RS
ok, but in any case, i know for my concious, i felt better putting a delete pulley in
Old 04-21-2007, 12:15 PM
thomas1976's Avatar
Car: 91 Trans am
Engine: built 360 TBI
Transmission: built 700r4
Axle/Gears: 10bolt/3.23
Old 04-21-2007, 05:35 PM
Gallileo60's Avatar
Car: 89 RS, 92 Z28
Originally Posted by thomas1976
Gallileo, why would you waste your time on removing it?
It is ugly as sin, and the look without it is much cleaner......Also, I know we are talking only a pound or 2, but 100 pennies will make a dollar.Another reason is, it is alot easier to work on some things, when there are less things in the way, BUT the most important reason for me, is I just dont like the thing...LOL..........I lay in bed at night, and think about how much I hate my smog pump...It haunts me...I am a shell of a man because of my smog pump, i've lost weight, and cant sleep anymore..
punksmacker (02-28-2020)
Old 04-21-2007, 06:02 PM
wahoo's Avatar
Car: Camaro RS 1992
Transmission: TH700R4
Removing the smog pump is a good idea.
I will do it too.
Just one question...
On these diagrams, if I remove the smog pump, can I use the stock belt with the new belt route or should I change it?
Old 04-21-2007, 11:04 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
I will do it too.
You need a different size belt. You cannot re-use the stock belt.
Old 04-21-2007, 11:49 PM
91forever's Avatar
Ive been running without the smop pump for about 6 months and it works great. Just follow the delete article here and it will be ok.
Old 04-22-2007, 01:29 AM
what he said
Old 04-22-2007, 05:29 AM
Gallileo60's Avatar
Car: 89 RS, 92 Z28
I feel better already.................
Old 04-22-2007, 06:26 AM
thomas1976's Avatar
Car: 91 Trans am
Old 04-22-2007, 12:46 PM
hot92RS's Avatar
Car: 92 Z-28
Transmission: THM700R4
Shifty, do you have a part number for the belt that is required for this delete? Any help appreciated.
Old 04-23-2007, 04:59 AM
beatercoprice's Avatar
Car: 92 & 93 caprice 9c1's
Engine: L05's
Transmission: 4L60's
Axle/Gears: 3.42's one G80, one open
Read the tech section guys, I cant remember right off hand but it tells you what belt you need and everything. Getting rid of the smog pump also frees up a few horsepower. Didnt even throw a CEL on my caprice when I did it.
Old 06-18-2011, 03:43 PM
clean92rs's Avatar
Car: 92 camaro RS
Engine: Vortec 355,262/268 cam,670holley
Transmission: 5speed
if i remove my smog pump do i have to weld my air tubes shut or put headers on? or will it be fine as is?
Old 06-18-2011, 10:15 PM
RyanEricW's Avatar
Well you need to plug the manifolds, also need to make sure the cat is plugged too or you'll have somewhat of an exhaust leak. I badly want to remove mine, but I don't want any drivability concerns, or the value of my car to go down.
Old 06-25-2011, 04:42 PM
Gallileo60's Avatar
Car: 89 RS, 92 Z28
Been gone off mine for years, no problem..Just put plugs in the manifolds, and either get rid of the cat, or plug the tube..A shop did mine for me the first time with a "test tube" now with headers it is even better, my 89, and 92z are both like that..
Old 06-25-2011, 06:38 PM
dewfamily's Avatar
Car: 1991 RS camaro
Engine: 5.7
Axle/Gears: peg leg for now
after removing the air tubes and pump, do I need to have the computer reprogramed? I have read alot of conflicting stories.
Old 06-25-2011, 08:56 PM
torque_is_good's Avatar
nope
Old 06-27-2011, 12:29 PM
KITT1983's Avatar
Car: 1983 Pontiac Trans Am Daytona 500
Engine: Crossfire 305ci V8
Transmission: Jasper 700R4 4 speed Automatic
Axle/Gears: 3.23 limited slip/posi
How do you remove the egr and diverter valve without the check engine light coming on and will the motor running like crap
Old 06-27-2011, 12:40 PM
RyanEricW's Avatar
Leave the EGR for better fuel economy...
The egr, recirculates exhaust gas at cruising (light throttle) to improve mileage. The EGR does not affect performance at WOT.
Old 01-19-2014, 08:58 PM
83ChevCamaro's Avatar
I'm going to get rid of my smog pump and everything that goes with it. My factory therm housing has two ports on it one for coolant sensor and the other for thermal vacuum switch (which has to do with the smog system) I'm guessing I will need to get a new therm housing with one port for the coolant temp sensor or plug the second port on my factory therm housing where the thermal vacuum switch is?
Old 01-19-2014, 09:53 PM
one92rs's Avatar
Car: SOLD!!!!!
if you have a port in the front of the intake use that one for the coolant sensor. you know a thermostat housing for even a 1969 Camaro will work that has no holes in it. I have a 92 Camaro and that is what I am using.
Old 01-20-2014, 05:58 AM
KITT1983's Avatar
I have a 83 ta and my stock thermostat housing has no holes for the coolant temp sensor. The CTS mounts on the intake right above the thermostat housing.
I removed the smog pump, egr & solenoid( my egr solenoid was shot and discontinued), A.I.R. lines, no check engine light after five years.
Old 01-20-2014, 06:00 AM
KITT1983's Avatar
83 chev what motor do you have?
Old 01-20-2014, 06:24 AM
Thanks for the info. It's a 305 v8. Anything else I should consider while I have the motor out and painting the bay? I live in ga so I'm going to have to keep my heat and AC. Have thought about re routing my air lines so the don't go over the radiator. I would like to get rid of the clutch fan and go electric. Any of y'all done that or have any tips?!
Old 01-20-2014, 06:36 AM
KITT1983's Avatar
I still have my heat and A/C on my 305 CFI. Pm me some engine bay pictures. Removing my cats and the egr diverter valve unit (its been bypassed and disconnected. No cells.). TBIparts on eBay sells a nice egr block off plate.
Old 01-20-2014, 07:45 AM
Yes egr valve for sure. Also I'm going to remove the charcoal canister and windshield wipers. Just have to did something to cover the hole where the wiper motor was. I'll pm you some pics when I get off work today if I have time. If not tomorrow.
Old 01-20-2014, 08:31 AM
KITT1983's Avatar
why are you removing the wipers ?
charcoal canister i heard is tricky on eliminating. I have not removed mine yet.
Old 01-20-2014, 09:31 AM
Removing the wiper motor cleaned up the engine bay a good bit especially the washer fluid res and hoses. Plus I'm going to use the car for weekend/ special occasion don't plan on driving it in the rain.
I read to remove the charcoal canister:
Remove all vacuum tubing
Cap the throttle body nipple
Put a PCV breather on the canister pressure check valve to cap the fuel line from the tank (which can be put closer to fuel tank and not in engine bay)
And close the addition vacuum nipple on top of check valve with some JB weld or equivelant.
Old 01-20-2014, 10:43 AM
KITT1983's Avatar
I would advise against removing the wipers because the weatherman still can't predict the weather. One day they say it was going to be 70 degrees and sunny all day. As I was driving from a car show a flash down pour comes down.
Old 01-20-2014, 05:05 PM
Schurkey's Avatar
Smartest thing said in this entire thread.
Old 01-06-2015, 10:23 PM
zachbulthuis89's Avatar
Car: 1898 camaro rs
Engine: 5.0
Hey guys, I have an 89 camaro rs 305 TBI, and I took the stock manifolds off and installed shortie headers and I removed the air lines and the hoses and housing they connect to, and I ordered a smog delete pulley and will be removing the smog pump and installing the delete pulley. With a delete pulley will I need a new serp, also what have people done with the air select and air divert sensors that plugged into the plastic AIR/smog housing? They look like they are in a loop so if I connect them to each other and put electrical tape over the connections? Or just leave them not connected to anything? Any help on the smog delete and those wires appreciated, thanks guys
Old 01-07-2015, 11:46 AM
Schurkey's Avatar
I guess you should have bought the headers WITH the AIR plumbing. That would have ended all your AIR problems.
Old 01-07-2015, 01:18 PM
Formula 305's Avatar
Car: 1990 Formula Firebird
Engine: 305 TBI (LO3)
Transmission: WC T-5 out of an 88 T/A
Axle/Gears: 10 bolt, 3.42 & Torsen Posi
Bad newbie. Don't bring new life to old threads.
Remove all the sensors/valves associated with the AIR system, wrap the connectors up with some electrical tape & zip tie them away from any hot or moving parts. Done.
Old 01-07-2015, 01:20 PM
hwcoll95's Avatar
Car: 1989 Iroc rebuild
Engine: 355 carb'd
Transmission: 5spd
Axle/Gears: 3:08 pos for a while
i removed everything smog pump related except the wiring harness,with delete pulley i put original belt back on it,had the longer belt on the re route
[IMG][/IMG]
Old 01-07-2015, 09:34 PM
sootie007's Avatar
Car: 91 RS VERT
Engine: 305 9.67 2.02 58 cc 282 480 108 LC
Axle/Gears: 4.11 POSI
https://www.thirdgen.org/forums/tbi/...lete-info.html
Go to post 40 for pics and p/n for belt .
Old 01-07-2015, 09:36 PM
sootie007's Avatar
Car: 91 RS VERT
https://www.thirdgen.org/forums/tbi/4...lete-info.html (Smog pump delete info needed)
Old 10-18-2015, 08:37 PM
Sir ian's Avatar
Car: 1991 Camaro RS
Engine: V-8 305
Does anybody know What can i plug the manifold and everything else with so I don't have an exhaust leak when I remove the smog pump and put a shorter belt on?
Old 10-19-2015, 02:47 PM
Schurkey's Avatar
Consider NOT removing the pump, and NOT putting on a shorter belt. FIX the system if the pump or other parts have become defective. Problem solved.
Quick Reply: Smog pump delete info needed
