What size Weld Prostars or Draglites will fit stock IROC?
Old 02-13-2007, 08:29 AM
titan20's Avatar
I know I could look a the backspacing charts all day long, but I want to get input from people actually running these wheels on a Camaro. I have a 87 IROC. I pretty sure I want to go with 15x8s in the back and 15x6 or 15x7 in the front, with a 275/60 in the back and probably a 225/60 or 235/60 in the front. Exactly what backspacing and offset to a need for this to work (and not stick out in the back like a skateboard)? My car has rear disc brakes -- are there any clearance issues with 15" wheels? Thanks.
Old 02-13-2007, 10:43 AM
online170's Avatar
Car: 1987 Firebird
WAY TOO MANY Threads on this already. Use search for backspacing, or biggest tires, or 15" wheels, theres lots on info.
Old 02-13-2007, 11:58 AM
titan20's Avatar
I understand the frustration about repeat posts, but sometimes it's hard to find exactly what you need to know. I have been weeding through posts since I posted this question (sorry I didn't do it sooner). I have found the size and lugnuts choices explained, but I'm not entirely clear on brake clearance in the back. From what I gather, the wheels will probably hit, and my two choices are to run a backspacing that will make the wheels stick out and look retarded, or to grind my calipers down or use spaces (well, actually that's three choices), and none are appealing to me. If I'm wrong, someone correct me. If this combo doesn't work out, I'll probably stick with my GTA wheels on a Camaro for now, and maybe look into Torque Thrusts or Hopsters in a 16 or 17" size later. By the way, in defense of the "repeat post", if no one did it, there would nothing on these forums. I'm sure practically every Camaro or Firebird question has been asked and answered about 1,000 times. However new members still want to know certain things, without weeding through thousands of posts, and still not finding what they need to know. But I apologize just the same to the "veterans" of this forum.
Old 02-13-2007, 12:31 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
15x8 with 4.5 bs
15x4 for front
275/60R15 drag radial
165R15 front
that's what is on my camaro. Bigger fronts look retarded on these cars. If you have to grind some caliper fins on the back oh well, everyone with LT1 and LS1 cars have to do it as well.
Old 02-13-2007, 02:25 PM
titan20's Avatar
Thanks!!! I think I might have seen one of your posts when I was searching, and you advised someone else about using longer wheel studs. It's been so long since I ran a car at the dragstrap (about 10 years), I don't remember all the tech stuff. In fact, the dragstrip I run at didn't even tech "street" cars (I know they had a tech booth, but for whatever reason, I didn't have to go through it). Is the longer wheel studs a quickness issue -- i.e. 13.99, 12.99, etc. and under, or is it for every car? I don't entirely understand how a "shank" lugnut would work with longer studs (and I don't see how an open lugnut would seat inside a Weld or other similar wheel. I don't have access to an air grinder, but can I assume that a dremel would work just as well on the back brakes if I have to go that route? Thanks again.
Old 02-13-2007, 09:15 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Depending on the size of the rear tires, you can go up to a 15 x 10 with 5.5" backspace on the rear.
Both Draglite and Pro Star rims require longer wheel studs and shank wheel nuts that use washers. The center hub is too thick for factory studs.
Jeremys87
07-14-2022 09:08 PM
MoJoe
Fabrication
08-19-2017 07:12 PM
wruiz
08-13-2015 09:07 PM
mustangman65_79
08-11-2015 03:17 PM
knight72
08-10-2015 09:32 PM
Quick Reply: What size Weld Prostars or Draglites will fit stock IROC?
