Alternative Port EFI Intakes This board is for tech discussions and questions about aftermarket port EFI such as the HSR, MR, SR, BBK, FIRST, etc.
Porting LT1 intake
Old 02-09-2007, 06:02 PM
LB9GTA's Avatar
Car: '91 GTA
Engine: 421sbc
Transmission: Powerglide
Axle/Gears: Ford 9" with 3.89
Porting LT1 intake
Right now I have a converted LT1 intake.
It has a 48mm throttle body on it.
Do you think I could port the opening of the intake like the miniram for a 58mm throttle body?
By this I mean cut it into 1 big oval hole rather than 2 holes.
I want to do it now while the intake is off the motor rather than wait until I have more $ down the road to get a 58mm tb and get shavings in the intake.
Old 02-10-2007, 02:54 PM
camarodarrell's Avatar
You can do that or you can just port it to 58 mm without cutting the middle out. Just be sure not to open up the little hole in the center on the bottom.
Old 02-10-2007, 07:59 PM
LB9GTA's Avatar
Car: '91 GTA
Engine: 421sbc
I just looked at the intake.
I think it it ported already but I am not sure.
Can anyone measure their miniram or lt1 to see how big the holes are for a 58mm throttle body?? Please?
Old 02-10-2007, 08:12 PM
vernw's Avatar
Axle/Gears: 4.11 posi Ford 9"
58mm openings = 2.28 inches (just over 2 and 1/4 inches diameter
Old 02-10-2007, 10:32 PM
LB9GTA's Avatar
Car: '91 GTA
Engine: 421sbc
After I posted that question, I slapped myself on the forehead.
That's self explanitory
Cool, it's already ported!
Any other porting I can do to the intake before I put it on?
Old 02-11-2007, 01:17 PM
vernw's Avatar
LOL - I understand that one, been there and done it myself far too many times. Almost have a permanent bruise on my forehead....
Not a whole lot else you can port on those from what I've seen. Not much "meat" around the ports to allow much porting without welding on material. Watch your corners around the water passages, several folks weld on material there to stop small coolant leaks from what I've seen and heard.
92projectcamaro
01-18-2016 08:00 AM
86CamaroDan
09-29-2015 10:08 PM
New2Chevy
09-28-2015 12:35 AM
Jake_92RS
08-11-2015 10:39 AM
Quick Reply: Porting LT1 intake
