TBI INJECTORS COLOR CODE
Where at on the injector is the color code located at? Also, I would like to have a chart for the injector color codes.
Thanks!
Thanks!
check here, i posted i table a week or so ago.
https://www.thirdgen.org/messageforu...ML/000140.html
(A.K.A FireBird88)
AOL SN: Zander0710
1992 Camaro RS 25th anniversary edition Adopted Feb,14 2000
Mods:
14x3 Open element w/ K&N filter, MSD GM blaster Coil and 8.5 SC wires, AFPR, 60psi. Fuel Pressure gauge, 3-Row Al rad. , 180* t-stat, Hooker 1 5/8 headers, 3" Catco cat, 3" Hooker Aero Chamber cat-back, "Ultimate TBI" mods
(A.K.A FireBird88)
AOL SN: Zander0710
Mods:
Thanks but where are the colors located at?https://www.thirdgen.org/messageforu...ML/000140.html
Car: Turbo Buick
Engine: 3.8 V6
on the top of the injector between the terminals, theres a little "mushroom" shaped thing that the injector plug snaps onto, this has the colors painted on there on side will have green the other will have white etc the colors dont last long dont be surprised if you dont see any, sometimes you have to look real close to see any remnants of the injector colors
LT1Formula
08-20-2015 09:36 PM
