Where to pour Oil!!!
Old 10-14-2006, 04:17 AM
Maxtor102's Avatar
Car: 1985 Trans AM
Engine: 305 TPI 5.0L
I went out today spent around 58$ in filters and such and oil but i ran into a problem i pop open my hood and look in there is no spout for the oil pour in i see on the power steering in front with the belt hooked up (greenish Yellow color i see the dip stick for Oil then the dip stick for tranny but no spot that screams pour oil here. Sorry about this but im just damn confused.
Make Pontiac
Module: 1985 tpi T/A 305 5.0 V8 FI
Old 10-14-2006, 04:22 AM
EvilCartman's Avatar
Car: '82 Z28
Stock valve covers should have an oil cap, they don't always necessarily say OIL. Since I don't have stock valve covers, I just remove the PCV valve and take my time pouring the oil through that hole into the valve cover.
Old 10-14-2006, 09:52 AM
Vader's Avatar
Which all reminds me of the old urban legend/tale about the novice service station attendant (Anyone remember those - People who actually pumped your gas, checeked your fluids, washed the windows, checked tires, etc.? ) after checking the oil and discovering it was a quart low, he added oil by pouring it all over the engine. The explanation was that "The entire engine needs oil, so I put it everywhere."
Old 10-14-2006, 10:44 AM
82 Iron Duke's Avatar
Car: 04 Silverado
Engine: 4.8
Transmission: auto
Old 10-14-2006, 03:31 PM
MaxxMitchell's Avatar
Car: 87 Firebird
Engine: 5.3 76mm
Transmission: Rossler TH400, PTC converter
Axle/Gears: Strange 12bolt, 3.08s
Wow.
Old 10-14-2006, 04:48 PM
Maxtor102's Avatar
Car: 1985 Trans AM
gave up on changing the oil today when spending about 45 mins trien to get the oil pan bolt off so i finished off setting up the intake.
anypointers on getting stuborn bolt to move?
Old 10-14-2006, 06:45 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
just poor it into your throttle body.
Old 10-14-2006, 11:22 PM
BlkBird408's Avatar
Car: 89 Firebird
Engine: 408
Axle/Gears: 12 bolt/4.11
Old 10-15-2006, 01:15 AM
Burntz's Avatar
Car: 1986 Trans Am
Engine: Mild 10:1 355.
Axle/Gears: 9 bolt
idk if this kid is being dumb on purpose or not, but um.. yea,
Cap - on - valve - cover
turn it
pull off
pour oil in
put cap back in
tighten
Old 10-15-2006, 02:43 AM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Any hole in either valve cover is fine for putting oil in.
Old 10-15-2006, 03:50 AM
Maxtor102's Avatar
Car: 1985 Trans AM
+++ Sigh i ment the oil pan drain plug
as for the intake was just finishing up installing the duct part as my car didn't have one to start with.
Old 10-15-2006, 08:03 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
I would just drill a hole in your oil pan next to the bolt, and when you are done, Tighten a screw into your newly aquired hole to prevent leaks.
Old 10-15-2006, 08:32 AM
2kflhr's Avatar
Car: '68 396 SS/RS, '02 SS
So you spent 45 minutes trying to get the drain plug out and still didn't I gather, and don't know where to put the oil back in once you get the old oil out. So you decided to "set up the intake" instead.
I'm the one confused!
Old 10-15-2006, 08:42 AM
IROC-You's Avatar
Car: 87 IROC-Z28
Engine: 414ci Twin Turbo
Axle/Gears: Ford 9"
God me too.
Old 10-15-2006, 03:06 PM
Maxtor102's Avatar
Car: 1985 Trans AM
sigh...
Well to help Clear things up i bought this car from a junk yard the car was stripped and also modified engine wise when i get my film devolped i'll post some before and after pics.
Here is the pic of the valve covers that are installed I know there Chevy but they got them to fit some how this is why i asked the question where to pour the oil. Edelbrock Classic Cast Aluminum Valve Covers: EDL-4145 - summitracing.com
As for the intake i was worken on the whole setup was missing filter, box, Maf, and ductwork
As for the drain plug the car was last driven in june of 99
(no frame rot only major thing was interior is shot)
I hope this clears up some confusion.
Old 10-15-2006, 03:14 PM
2kflhr's Avatar
I would suspect the engine is an earlier model if it doesn't have center bolt valve covers. Check the numbers, it could be anything.
Old 10-15-2006, 07:28 PM
Steve86TA's Avatar
Car: To many to list
85 wouldnt have centerbolts anyway.Those valve covers are for the early chevys,when they had the oil fill through the intake.I dont know what to tell you without a pic,but you may need some new valvecovers .02
Old 10-15-2006, 07:49 PM
Supervisor42's Avatar
Car: 1988 Trans Am GTA
Engine: 350 4BBL
Now see there, Y'all play nice. The previous owner obviously put on some very nice ribbed "pre-1968" valve covers on a 82-87 engine.
I think they're too pretty to throw away too.
So, if your 82-87 engine suddenly had these valve covers on it, what would you do to put oil in the engine?
This is a brain teaser for all of the smart people out there.
And don't even talk about the PCV, like where would the blowby come out?
Alright smart people...are you>
Old 10-15-2006, 08:16 PM
krly79's Avatar
Car: '93 S10 Short bed standard cab
Engine: 383 Stroker
Transmission: 92' stage 2 700r4 w/3600 stall
If it is pre '68 then it will have a vent tube at the back of the intake by the dizzy that was a crankcase vent (also called a road tube or something like that) that worked like blowing over a straw to vent oil vapors so it would not sludge. You could fill it there. Otherwise you will have to fill it though your dipstick tube.
Old 10-15-2006, 08:29 PM
Engine: 350 4BBL
Originally Posted by krly79
...back of the intake by the dizzy that was a crankcase vent (also called a road tube or something like that)...
The correct term is "snot pipe".
And his block is newer than '70.
jrdturbo
03-31-2016 02:58 PM
bigjay89gta
10-15-2015 08:04 AM
skinny z
10-05-2015 06:23 PM
mfp189
09-27-2015 09:25 AM
Quick Reply: Where to pour Oil!!!
