Which port on power steering box is the high pressure side?
Old 10-04-2006, 11:30 PM
SDIF's Avatar
Car: 91 Z/28, 89 RS Race Car
Engine: 305 stock / ZZ4 AFR 195 9.7:1
Transmission: T5 / t10 / Jerico
Axle/Gears: 10blt w 3.42, 9 in w /3.80 DL
Which port on the box is the high pressure die the small opeining or the large.
I am mounting an aftermarket pump and making the lines. Thought I would double check before cutting them.
Old 10-05-2006, 02:38 AM
ZimGTA's Avatar
Car: 88 GTA
Engine: 383
Transmission: 700 r
Small
Old 10-05-2006, 08:50 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
The port closer to the engine is the pressure port on the steering box. Which is the larger port on the metric boxes (uses a saginaw fitting & O-ring).
RBob.
Terrell351
06-13-2021 01:13 PM
Vintageracer
01-10-2020 05:33 PM
colton_carlson
03-08-2019 12:21 PM
jackhammer
08-15-2015 10:04 PM
mx127
08-10-2015 08:13 AM
Quick Reply: Which port on power steering box is the high pressure side?
