proform carb setup question
Old 09-07-2006, 11:48 AM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
my new proform 750 carb has clear sight plugs, do I set the levels to the middle of the sight plugs or the bottom?
Old 09-07-2006, 02:42 PM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
If the sight plug hole is at the same level as a stock holley sight hole set it at the bottom as a starting point. You can fine tune the main jet fuel responce by adjusting the float height from there. Raising the float height a little will cause the mains to start fuel flow sooner. Flooding and fuel slosh bogging is too high of a float setting.
I usually run the secondary float height a little higher than just dribbling out the sight hole.
Old 09-07-2006, 03:13 PM
xpndbl3's Avatar
Car: 1984 Z28
alright i'll check it against my other carb sitting in the garage for height, then adjust accordingly
Old 09-09-2006, 07:17 AM
jbenge's Avatar
Car: 1991 Camaro Z28
Axle/Gears: Strange 12 Bolt, 3.42
I ran my Proform carb just above the bottom of the sight glass around 1/8 to 1/4 full. I've tried higher and lower settings but thats what works best for me. F-Bird is right you can use float levels as a tuning aid, it may take some trial and error. I just put a Pro-Systems carb on my car it it required a higher float level around 1/3 full..and thats what they recommended.
Old 09-09-2006, 04:45 PM
xpndbl3's Avatar
Car: 1984 Z28
alright i have the primaries at the bottom and the secondaries a little higher and it seems to run alright so far, but i'll make fine tuning adjustments as I go. This carb is certainly a much more tunable platform than my old 850 dp holley was.
Frozer!!!
01-19-2024 04:55 PM
MustangBeater20
10-29-2022 09:20 PM
pimp2303
07-27-2017 02:03 PM
theurge
08-21-2015 12:46 PM
redmaroz
08-16-2015 11:40 PM
Quick Reply: proform carb setup question
