How to install a new ignition(Tumbler and key)
Old 09-07-2006, 01:25 AM
BigBoi4Lyph's Avatar
Car: 89 Iroc
Engine: 5.7 TPI
Axle/Gears: 9 bolt Borg Warner Disk Brake Posi
So how do i go about this im buyng a new ignition and key set how do i get the old one out... it dosent have a key so i have no clue how ti get ito ut thanks!
Old 09-07-2006, 01:29 AM
AdamsIroc-Z's Avatar
Car: 1987 Camaro Iroc-Z
Engine: Built 355 LT1 T-Trim
Transmission: T56 6 spd
Axle/Gears: 9 bolt 3.73 gears
The column will have to come appart starting with the steering wheel and working your way down. You will need a gm special tool to ensure you don't break anything when pulling the spring loaded parts out.
Old 09-08-2006, 10:13 PM
tom3's Avatar
Car: 88 Camaro
Engine: L98 350
Have to pull the steering wheel, take out the lock ring under this and the turn signal canceller, then you'll see a small bolt next to the tumblers. Remove this bolt and the tumbler will pull out. Pretty easy if you have a steering wheel puller and lock ring depresser. Still do-able but harder without the tools.
BRoss99
12-07-2020 06:50 PM
Vintageracer
01-10-2020 05:33 PM
Out-Cast
03-22-2019 09:39 PM
9192camaro
16
02-03-2019 12:21 AM
Bryan F
08-18-2015 02:28 PM
Quick Reply: How to install a new ignition(Tumbler and key)
