How to tell the difference between 650 and 750 double pumper?
Old 09-03-2006, 12:44 PM
zacharyhorn's Avatar
Car: 91 Firebird
Engine: Turbo 355
Axle/Gears: 3.73:1 7.625" 10 Bolt
I was wondering how to tell the difference between a Holley 650 and 750 double pumper? I need a 750 double pumper and my cousin down the road has a holley carb and he's not to sure what it is. How can I differentiate the carb?
Zach
Old 09-03-2006, 01:50 PM
red406's Avatar
Car: '84 Z28
Engine: 406 sb
Transmission: th400
Axle/Gears: Moser M9/5:14 ratio/Billet Locker
(I think) There should be some numbers on or around the choke horn. Get thease numbers and do a search online.Or, If you knew what size throttle bores a 750 dp has you could flip the carb upside down and measure the diameter of the throttle plate bores with calipers. I wish I could help you more.
Old 09-03-2006, 01:54 PM
red406's Avatar
Car: '84 Z28
Engine: 406 sb
Transmission: th400
This might help you. MorTec lists Holley carb specifications, list #'s, jetting and tuning tips.
Old 09-03-2006, 05:55 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
750 is a 4-corner idle carb, and a 650 is not. IIRC, that means that the 750 will have idle mixture screws on the rear metering block, and the 650 (like mine) will not.
On the choke horn, it will also have the PN that will identify the carb. 650 is 4777, and a 750 is 4779.
Old 09-04-2006, 11:38 AM
Car: 91 Firebird
Engine: Turbo 355
Thanks for the replies guys. I should be able to tell now.
Zach
Old 09-07-2006, 06:09 PM
rabrand's Avatar
Old 750 DPs like 4779-2 arent 4 corner idle.
Hotrodboba400
12-10-2019 07:07 PM
my86bird
10-23-2015 12:20 PM
BAMiller
09-14-2015 06:38 PM
Hotrodboba400
09-02-2015 07:28 PM
greenyone
09-02-2015 03:39 PM
Quick Reply: How to tell the difference between 650 and 750 double pumper?
