Could a bad oxygen sensor cause a rough idle
Old 08-21-2006, 09:40 PM
Jetmeck's Avatar
Car: '89 GTA 9,000 MILES
Axle/Gears: 3.27 9 bolt
after going into closed loop. 89 TPI.
Car idles normally until it warms up enough to go into closed loop. I searched and found little info. Thx
Bill E.
Old 08-22-2006, 08:02 AM
8492bird's Avatar
Car: 84-92 firebirds
Engine: 2.8/3.1
Transmission: auto
The short answer to your question is yes. If the O2 is bad and reading lean all the time the ECM will richen the A/F mixture, causing a rich condition, in turn causing a rough idle. If the sensor has'nt been replaced in a while, go ahead and replace it.
Old 08-22-2006, 12:31 PM
Jetmeck's Avatar
Even with no codes ?
Old 08-22-2006, 12:36 PM
8492bird's Avatar
Engine: 2.8/3.1
Transmission: auto
If the sensor is still putting out a mV signal a code won't be thrown for the O2 sensor. I'm not sure what triggers the ECM to throw a lean or rich code though.
Old 08-22-2006, 12:41 PM
Jetmeck's Avatar
Thx
Old 08-22-2006, 11:16 PM
rx7speed's Avatar
Car: 2005 BMW 545i
Engine: 4.4L N62B44
Transmission: 6spd auto
Axle/Gears: Rotating
from my understanding the o2 doesn't work all that well at idle speeds so at idle itself more or less it gets ignored until you apply a little throttle. at least with most every car I have seen it's about right. just like the O2 also gets ignored more often then not at WOT.
if you don't mind just out of curiousity is there a chance to disconnect the O2 while your car is warming up see if it runs ok afterwords.
I'm fairly sure it would still run ok but honestly I'm not 100%
bamaboy0323
09-03-2015 06:07 AM
beast94
DIY PROM
08-20-2015 06:44 AM
Bradsaundry
08-12-2015 12:34 AM
Quick Reply: Could a bad oxygen sensor cause a rough idle
