Rims - Convo Pro's on a IROC-Z?
Old 08-14-2006, 10:59 AM
1987_Blue_IROC's Avatar
Car: 1987 IROC-Z
Transmission: TH700
Axle/Gears: 3:27
Hi.
About rims, Center Line Convo Pro, 15in.
Any of you have any experience with Convo Pro's on a IROC-Z?
Do they have any 15in-size that would fit?
How about this:
Front: 215/60/15 (15in x 6in)
Back: 245/60/15 (15in x 8in or 15in x 8,5in ?)
Any suggestion?
Thanks for any help!
Old 08-14-2006, 02:02 PM
brutalform's Avatar
Welcome to Thirdgen!
I run them at the track on my Formula. 15x8.5, with 5" B/S in the rear, and 15x4 in the front. I would not use them on a driver though. One pothole, and they will be trashed.
8.5s would be better in the rear, IMO. Make sure you get the correct B/S, or they will look out of place.
Old 08-14-2006, 06:39 PM
Raven90IROC's Avatar
Car: 1990 Camaro IROC-T
Engine: L98 Turbo (GT40)
Transmission: THO400
Axle/Gears: Forged axles, 3.23 rear
Here a couple of shots of mine. Ive had them for ages now. I run 15x7 front and 15x8.5 up back. Cant remember the back spacing tho...
Old 08-15-2006, 07:10 AM
Car: 1987 IROC-Z
Transmission: TH700
Axle/Gears: 3:27
Thanks "brutalform"!
As I can see ( Centerline Wheels ) theres only one current BS at 15x8,5 rims. BS=5".
Would Weld Pro Stars be a better choice, or are they the "same" strength?
Raven90IROC, what is your rim size front and back? Any rubbing?
And what is your suspension setup (springs) ?
Thanks.
Nice cars you have!
Old 08-15-2006, 12:28 PM
brutalform's Avatar
IIRC, Weld wheels are a bit lighter than the Convos, and they are available with 5.5" B/S, which is better for our cars than 5". I was going to get Welds but I liked the Convo design a little better, so I went with those instead.
Old 08-16-2006, 11:51 AM
rat infested's Avatar
Car: 83 CAMARO 468BBC
Engine: 9.84 @ 138mph street driven
Transmission: TH 400
Axle/Gears: ford 9" 3.70 gears
I have 15x 8 with 5.5" back space on my 83 they look great I have some pics if I knew how to attach them !!
Old 08-21-2006, 12:47 PM
IROCZZ502's Avatar
Car: 1988 IROC-Z
Engine: ZZ502
Transmission: TURBO 400
Axle/Gears: DANA WITH 410 GEARS
Car looks awesome, what size are the rear tires?
Old 08-22-2006, 02:55 AM
Thanx mate I am running 8.5" convo-pro's with 28 x 9.0 x15 slicks Traction IS an issue but I have trouble running a bigger tyre as the arch comes down so hard on launch it tends to hit anything bigger
Old 08-25-2006, 03:29 PM
Car: 1987 IROC-Z
Transmission: TH700
Axle/Gears: 3:27
rat infested, are you running 8" or 8.5" ?
Where can I find pic's of your car?
IROCZZ502, what size are your Draglite's?
Thanks.
Old 08-25-2006, 07:05 PM
IROCZZ502's Avatar
Car: 1988 IROC-Z
Engine: ZZ502
My Draglites are 15x8 with a m/t 26x10.5, but this tire on an 8 inch rim is only about 9 inches wide, I want to put a bigger tire size like a hoosier QTP 27x11.5,but i'm not sure if the tire will fit.
Old 08-27-2006, 02:55 AM
1987_BLUE_IROC
My wheels are 8.5" x 15" with a 5.5" backspace ( a little massaging to fit with Mickey T 295/15 tyres) ther are some pics and more details of my car at car domain try this link ( it should work) 1983 Chevrolet Camaro - Craig's Chevrolet
Old 08-29-2006, 01:36 PM
Car: 1987 IROC-Z
Transmission: TH700
Axle/Gears: 3:27
As I can see from Center Line's web site, Convo Pro's can be ordered at this size/backspace:
15x8.0" --> BS 4.5"
15x8.5" --> BS 5.0"
15x9.0" --> BS 6.5"
Right?
So if I want Convo's 15x8.5"-bs5 is the way to go?
Prostar and Draglite can be ordered as 15x8"-bs5.5 I think.
Hard to decide what to choose... Convos, Prostar or Draglite...
Anyway, Thanks for all replys!
Old 08-30-2006, 02:38 AM
86birdHT's Avatar
Car: 2004 Pontiac GTO
Axle/Gears: IRS 3.46
IMO id go with the draglites...They're just real good looking and on a camaro im sure it would look a hell of a lot better.
Old 08-31-2006, 08:39 AM
Convo Pros FTW!!!
:P
Old 09-01-2006, 06:50 AM
Car: 1987 IROC-Z
Transmission: TH700
Axle/Gears: 3:27
Like it! Very nice !
What are your tire setup (front & rear), and springs ?
Old 09-02-2006, 09:09 AM
Dear 1987_BLUE_IROC I am a dumbass I was getting mixed up with the wheel size I am running 8.5" x 15" x 5" back space !!! While I'm on does anone know if I can run a bigger slick than my M/T 28" x 9" x 15"'s I was looking at a 10.5" tyre (oops sorry forgot you guys spell it different TIRE) . but I cant take anymore metal out behind the wheel or off my arches Any Ideas ??
Old 09-04-2006, 10:16 AM
In that pic im running 235s up front (cant remember the wall size) with K-mac 1.5" lowering springs and 275/60/15s up back with K-mac standard high springs and HD shocks.
LiquidBlue
Wheels and Tires
32
12-10-2019 04:06 PM
BrianChevy
Wheels and Tires
08-08-2019 02:16 PM
dbrochard
Exterior Parts for Sale
10-10-2015 01:03 PM
88CamZ
10-08-2015 10:29 AM
djmarch
10-02-2015 10:41 PM
Quick Reply: Rims - Convo Pro's on a IROC-Z?
