Running a water pump BACKWARDS!?
Old 08-03-2006, 01:58 PM
gclay's Avatar
My son has a Monte Carlo (I know not a Camaro...I'm working on him)
wih a 3.1 6 cyl engine.
The Air conditioning compressor has completely seized (The car wouldn't even start). It has a serpentine belt.
THe only way that the mechanic could bypass the Compressor (Very expensive to replace) was to put on a smaller belt and route it around the water pump backwards.
Is my son going to run the risk of damaging his car by running it this way?
AtDhVaAnNkCsE
George Clay
Old 08-03-2006, 02:09 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
need an idler pulley off a non a/c one
it isnt gonna pump water like that and it wil overheat and then you can say bye bye engine then
or at least the heads
for real
dont drive it like that
good luck
Old 08-03-2006, 02:16 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
water pumps are directional.
however, for the SBC, you can buy water pumps that go either direction.
a "standard rotation" or "v-belt" waterpump turns the same direction as the crank. aka runs on the 'inside' of the belt.
a "reverse rotation" or "serpentine belt" waterpump turns the opposite direction as the crank. aka runs on the 'back' of the belt.
if you're swapping directions, you need to swap pumps.
Old 08-03-2006, 02:24 PM
87IROCZ350TPI's Avatar
Car: 87 IROC
Engine: 5.7 TPI
Transmission: 700-R4
Axle/Gears: BW 7.75" 3.27
Absolutely, that mechanic has no business touching a car if he doesn't know that. That situation has to be remedied IMMEDIATELY if the car is to be driven.
Old 08-03-2006, 03:00 PM
gclay's Avatar
I thought as much...Thank you all!
lakeffect2
08-23-2015 08:44 AM
eightsixseven
08-14-2015 03:09 PM
Zachattack0925
08-12-2015 09:54 PM
Zachattack0925
08-12-2015 09:52 PM
Street Lethal
08-12-2015 11:33 AM
Quick Reply: Running a water pump BACKWARDS!?
