Car shakes from takeoff
Old 07-18-2006, 08:18 PM
Camaro_87's Avatar
Car: 1987 Camaro Z28
i just bout a 87 z28 with a high performance 355 engine while driving it home i noticed from takeoff when i really give it gas the car shakes alot and i can't even get the tries to spin the previous owner said i have to use the really good gas in it but instaed i used something else could this cause it or is there something else wrong?? the he also said it never shaked from takeoff with him. what could it be??
Old 07-18-2006, 08:31 PM
ZEEYAA's Avatar
Car: 1991 Z-28
Engine: 383 / TPIS MINI RAM
Transmission: 700-R4
Axle/Gears: MOSER 9IN 3.89
It may be, because I think all our v-8 require at least 91 oct. What kind of crap gas did you put in it? Did you notice any spark knock? And what do you mean the car shakes?
Old 07-18-2006, 09:05 PM
Camaro_87's Avatar
i didn't really put crap gas in it but it wasn't as good as the gas im supposed to use. and spark knock what is that? and by shaking i mean when sitting in the car and from a dead stop i give it gas the car itself shakes not really hesistates but it vibrates alot and like i can't even do a burnout. bu twhat im gonna do is finish the gas thats in there completly , it;s almost on empty now and put the right gas in it and go from there.
Old 07-18-2006, 09:09 PM
3.492rs's Avatar
Car: 89 IROCZ
Engine: L98 4150 carb
Transmission: Transgo 700-r4
Axle/Gears: 10 bolt/3.23
sounds like wheel hop
Old 07-18-2006, 09:16 PM
Camaro_87's Avatar
wheel hop?? what is that never heard that before.
mnorton's Avatar
Car: Red 1987 IROC Convertible
Engine: 305 LB9 TPI
Transmission: T5 5-Speed
Axle/Gears: 9-Bolt 3.45
Sounds like the engine is missing on two or three of cylinders to me....
Old 07-18-2006, 09:20 PM
Camaro_87's Avatar
other then the shaking form takeoff ir runs good we were doing around 120 on the highway for about an hour straight with no problems
Old 07-18-2006, 09:24 PM
ScottieB's Avatar
Car: Blue 89' RS
Engine: 5.7L
check for a messed up spark plug wire. When is the last time you did a full tuneup? This sounds just like when my car was "missing"... one of the wires had a cut/hole/whatever you want to call in it, and it was sparking on a piece of metal. move your wires around while the car is on, and see if the idle changes. if it does, get a $20 spark plug wire set and replace them... But I would do a full tune-up if you haven't in a while.
Old 07-18-2006, 09:28 PM
Camaro_87's Avatar
Alright thanks for all the advice im going to try some things tommorow when i get home from work and ill let you guys know.
Old 07-18-2006, 11:22 PM
ChevyGuy87's Avatar
Car: 2004 Wrangler Rubicon
Engine: 4.0
Transmission: NV3550
Axle/Gears: Dana 44s with 4.10 and air lockers
Instead of moving the plug wires around while the engine is running, get a spray bottle of water and spray down the wires and distributor cap while it's running. If you're arcing anywhere you'll be able to see the sparks. I prefer this way, as I'm not a huge fan of being shocked by the ignition system.
Check a couple of your spark plugs, too. Or better yet, spend the $10 and put some new ones in.
Old 07-22-2006, 07:53 PM
Camaro_87's Avatar
hey sorry i didn't reply sooner busy week at work any way i took the car out for a quick ride considering i don't hav eplates or insurance yet for it but i notice that the car doesn't only shake from takeoff but if im sitting in the car in park and i rev the engine the whole car shakes and vibrates like just sitting in the drivers seat and reving the engine you can feel the seat vibrate.
Old 07-23-2006, 11:56 PM
hellfire's Avatar
Car: 91 Firebird
Engine: 305 tbi
Transmission: manual
Sounds to me like you need to rebuild the carb. Floats are probably your problem.
Old 07-24-2006, 01:36 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
your motor mounts aren't great any more. How "high performance" is this mystery engine? That'll make a car shake more then your average civic.
You need 91 octane at least. Run that until you find the problem and fix it, then you can try stepping down to cheaper gas. I don't think you'll get to though.
Make sure all cylinders are firing for sure. Maybe even pull the valve covers, and idle the car and make sure all your valves are opening. That's my latest malady..
Old 07-24-2006, 04:56 PM
Camaro_87's Avatar
i don't think it's the carb i have a brand new holley high rise carb on it. im not to sure how high performance this engine is but th eguy i bought it from said it was high performance that he put alot of money into that engine. a local performance shop custom built the engine for my car he said if i can ill post some pics but i tried and can't find out how to post them can someone tell me how?
Old 07-24-2006, 05:12 PM
Camaro_87's Avatar
Ok heres a link to a picture of the engine in my car
http://www.cardomain.com/ride/2413349/1
Old 07-25-2006, 09:12 PM
Camaro_87's Avatar
ok today i put some 94 octane gas in it and took it for a drive it ran alot smoother and didn't vibrate as much but it still has some vibration but not as bad im gonna try changing the plugs and wires and go from there.
Old 07-26-2006, 12:00 AM
Sonix's Avatar
Car: 1982 Trans-Am
i'd call up the previous owner and have a nice heart to heart about what's in that motor... You can't just fill up your car with gas, and drive it around as if it's a factory motor, when it's a custom built motor. Who knows, it might have 12:1 compression, a solid cam, etc etc. There are things you should know about that motor....
Old 07-26-2006, 02:31 PM
Dizturbed One's Avatar
Car: 92 RS
Engine: a slow one
Transmission: a crunchy one
Axle/Gears: a whiny one
^thats what i was thinking
you better be careful
i think you are causing detonation, and that's what the vibrating is... STOP getting on it, play with your timing a bit, and put good gas in it.
Frozer!!!
01-19-2024 04:55 PM
Reddeath210
10-06-2015 08:20 AM
Linson
08-21-2015 02:12 PM
kyleb24
08-15-2015 08:24 AM
bryan623
08-10-2015 11:33 AM
Quick Reply: Car shakes from takeoff
