Anyone using 101 Octane gas or higher???
Old 07-17-2006, 04:59 AM
techno101's Avatar
Car: 1989 Camaro RS
Engine: Modified 350 TPI
Transmission: Modified 700 R4
Axle/Gears: Posi 3.42
There are a few stations round here that carry 101 octane fuel. Even one station has 104 octane, race fuel is what the call it. Has anyone ever used this? I'm forced to use 91-93 octane because of my engine setup and PROM tune, but never got up the nerve to spend $4.50 on a gallon of gas. Anyone used it before??
Old 07-17-2006, 08:32 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
I'm sure alot of the race guys use it, and I'm sure alot of the old farts that were around in the good ol' days of leaded fuel used it as well. I myself, have not.
Old 07-17-2006, 08:59 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Unless you're running more than 11:1 compression ratio on the street, you dont need it. Octane is a fuel's resistance to burning. With high compression and lower octane, the fuel wants to ignite before the spark plug does. You need higher octane to control this. However, putting higher octane gas in an engine that doesnt need it will reduce power, as the fuel will not ignite as hard and will not have as much explosive force.
Old 07-17-2006, 11:04 PM
Air_Adam's Avatar
Right. You want to use the lowest octane gas you can in your motor without having detonation problems. That will give you the best mileage, the most power, and the least smelly exhaust.
Old 07-17-2006, 11:45 PM
urbanhunter44's Avatar
Car: '72 Chevy Nova
Engine: Solid roller 355
Axle/Gears: 8.5" 10-bolt 3.73 Posi
even my motor running 10.1:1 only needs 91.
KCG
06-24-2020 04:33 AM
GeneralIesrussi
Carburetors
01-20-2020 01:06 PM
2MNYMaros
09-15-2015 11:36 PM
Glowsock
09-11-2015 11:09 PM
Quick Reply: Anyone using 101 Octane gas or higher???
